跳转到主内容
Repair guides for the Samsung Galaxy J5 (2015), released June 2015.
47 个问题 查看全部
I can't turn on my phone. Why?
Hi I buy galaxy j5 at 2015 and worked fine till the battery got swollen around second month in 2018. The phone was discharging very fast and charging very slow and once when it get discharged won't turn on when i let it to charge. So I thought it was bad battery so I buy new one but still it won't turn on even the charging animation when turned off. So I was searching how to unbrick hard bricked phone and I found is jig So I order one from aliexpress but it didn't have the fifth contact I think so it didn't work so I buyed new one and I found old galaxy mini so I tried is jig on this phone and the new usb jig worked but for j5 didn't. I really don't know what to do now I'll be happy for every suggestion. Thanks Dalibor. Ps:sorry for mistakes I'm Czech.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@dalibortrampota you'll have to first identify which version your phone is. Something like J500F/J700FN (Global Single-SIM); J500F/DS (Global Dual-SIM); J500G/DS (Malaysia, Indonesia, Singapore, Thailand); J500Y (Australia, New Zealand); J500M (LATAM); J500M/DS (Brazil); J500H/DS (Philippines, Russia, Ukraine) will help. Not sure what jig you purchased on Aliexpress but I'd start with something like the Samsung troubleshooting flowchart.
Of course, you can always dig a bit deeper for something like this
Since you originally had the battery swell up, I would also consider a failed PMIC. Samsung has a separate repair guide for that Repair-guide-for-J500-charging.pdf
Update (04/14/2018)
component location for the No-Power chart
这个答案有帮助吗?
得分 2
3条评论:
@oldturkey03 i have J500FN and the first picture the flowchart i really dont understand to
完成的
*Most of all option
完成的
@dalibortrampota not sure what you mean by not following the flowchart. You need to measure the components listed in that image.
完成的
添加一条评论
have you tried to connect it to your PC?
can you go in download/recovery?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dalibor Trampota 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 890
