跳转到主内容
Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
20033 个问题 查看全部
Why is the MBP not charging?
Hi all.
Helping someone out with her macbook pro, all signs point to (99% certain) to the DC board connector.
The issue is the Macbook pro doesn't charge battery, or power on. (with AC connection alone), nor does the LED emitt at all. Yet with the AC disconnected and the battery in, the laptop runs just fine.
This points me directly to the DC in board as if it were the logoc board the mac would have problems on battery too.
The Macbook is out of warrenty
I'm simply asking just for conformation... Am I correct in that a replacment DC logic board would sove the issue ?
Just for the record, yes... i have reset the SMC ... and have replaced with new power adapter.. Still no good.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
Sounds like the DC-In board is correct to me. Please list the last three letters of your serial number to correctly identify your Book and get you to the right part and guide.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Seems to be the MOSFET. It is possible to replace it but you might have trouble finding it. If you cannot find it then you will need to replace the motherboard. I say give it a shot and maybe you get it to work :D
这个答案有帮助吗?
得分 1
添加一条评论
Sounds like your I/O board is bad, that is the only way that the battery can be charged. Does the indicator light on the Mega-Safe power connector lights up bright when connected to that port? if not, then replace that board first before you do anything else to it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
technet147 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 1,047
