跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
426 个问题 查看全部
Horn continuously goes off. Pulled relay.
Have a 2000 accord 4 cyc. Horn continuously goes off. Pulled relay. Brought to Honda. They say they have not seen this??? They swapped the airbag with a civic and said it solved problem. Wanted $1150 for new airbag. I did not do this there. Bought an airbag off ebay (used) for $90, installed it and then the relay. all was good until I pressed the horn in car. Switch engaged and latched on... Continual horn again so pulled relay. No idea what to try next?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@kevhavi I never resolved my issue with my horn, but maybe @oldturkey03 commented something that'll help you with your situation:
Am I able to replace the horn switch without replacing the airbag?
Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kevhavi 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 22
总计 1,128
