My charger doesn't charge.
After going down from lack of battery, my tablet won't charge. The charger Light doesn't turn on, and I need some solution that doesn't involve buying a new one or throwing everything against the wall...
@gc05 you could check your charger with a multimeter first to make sure that it is working. If it is then you are possibly having issues with either the charging port Microsoft Surface 充电口更换 or the battery. If your battery is depleted or discharged below the charging threshold it will no longer accept a charge. Replace the battery and see if that works. Microsoft Surface 电池组更换
指南
难度:
中等
5 - 10 minutes
指南
难度:
中等
15 - 30 minutes
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 44
总计 25,525
1条评论
Just tested with a multimeter, and apparently the charger is working...
The problem must be in the battery.
由 Gil Cancela 完成的 分享
