Handle on dustbin has come out of its fitting
Hi the handle on the Dyson animal big ball has come out of its fitting at the front, how do I get it back in as every time I use the handle the bin comes loose.
The dust bin is secured by a spring latch in the handle of the dustbin. Here is a picture with an arrow pointing at the spring:
Make sure this spring is properly seated and hasn't become loose or lost. Also check for any other damage.
If lost, here is a handle assembly for the DC65: https://www.amazon.com/Dyson-966060-01-H.... I'm getting conflicting information if this handle assembly is compatible with the DC75, but maybe you could replace the lost spring.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 15
总计 776
I am having the same problem with mine now! It’s not the spring as that is still in place! on mine it’s the red plastic piece that releases the bin (there’s a small crack in the corners of the plastic which has loosened the sides and prevents it from holding the bin in place anymore! I have searched the internet high and low and can’t find this part for the dc75 anywhere anyone have any ideas please?
由 Katie 完成的
