跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
Why does my ps4 keep on saying unrecognized disc?!
Recently my ps4 has been acting up everytime i put any game in it makes a weird noise inside and after about 30 secs it sounds like i just put a disc inside when its already in and another 20 secs it stops and on my tv shows its a unrecognized disc. Help me!! Ive tried doing the software update hard resetting it and cleaned the dust off from the sides and also ive tried standing it up and put the disc in but nothing works!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
13条评论
Just a suggestion but sounds like your DVD drive is faulty. Does it do it with every game disk you insert?
完成的
Yes every game i try
完成的
Mine does this too but just with my new game I bought today
完成的
Well I how do I fix the dvd part. Every time I put a disc in, it says unrecognized disc.
完成的
Like as in a dvd
完成的
显示更多的8条评论
添加一条评论
13个答案
最有帮助的答案
It's not the laser. If you tap above where the disc goes a couple seconds after you insert the disc it will work and read the disc. If it was a bad laser it would never read. And on the other hand my system is less than a year old how can my laser already be bad. Plus I've owned PS my whole life(28yo) and this is the first real problem that seems to have no answer to why it does this. I atleast hope the tap tip
这个答案有帮助吗?
得分 17
13条评论:
&&^&^$^ Genuis !
完成的
i cant believe the tap worked, thank you dude
完成的
Why does the tapping work!?!?!?!? I've been having this problem for over a year. Dirty insides? Something jamming?
完成的
I made an account just to say I love you haha thanks bro
完成的
Thank you!! it helped first time i tried! :D
完成的
显示更多的8条评论
添加一条评论
Your PS4 most likely needs a new laser. The lasers go bad over time and they just won't read anything. From your description of the problem that's probably what's causing it.
这个答案有帮助吗?
得分 5
添加一条评论
Tap the drive area it'll work I know it's not a permanent fix but will get u by
这个答案有帮助吗?
得分 3
1条评论:
Having the same problem won't read ANY DICS, tried your little tap method and VOILA!! LOL I'll work on the full issue later, but this will get me through tonight lol Thanks!
完成的
添加一条评论
If it reads when you tap on it, it’s probably not a broken laser, but a dirty/misaligned one.
这个答案有帮助吗?
得分 2
3条评论:
but for me it reads other games but not rocket league
完成的
when i tap on it it reads it but then it's says to close application and remove disc
完成的
I have the same problem it will read my red dead but not my GTA
完成的
添加一条评论
My PS4 slim will take in the disk and make a weird clicking noise like the rollers are still grabbing for something, but the disk will never spin and the unrecognized disk notification pops up. I’ve tried opening it up and cleaning the dust out, cleaning the laser with a q-tip, tapping over the disk, and even putting the disk in vertically while tapping and nothing works.
这个答案有帮助吗?
得分 2
2条评论:
Tried all of that cleaned out the PS4 stood it up vertically and horizontally then inserted the dics got a cd cleaner also. And put my PS4 in safe mode and tried all of that aswell and even unplugged it all out still saying unrecognisable disc even tapping soft and hard to get the disc to read and still nothing any other suggestions please to fix this problem
完成的
did you ever figure out a solution? I have the exact same problem as you.
完成的
添加一条评论
Having the issue of no discs reading at all. Can just play digital downloaded games. Also have 1st gen 2nd series so have to settle til ps5 bc not spending 300 on another ps4. Sell physicals and buy digtal (buy same game twice) only other option i guess
这个答案有帮助吗?
得分 1
添加一条评论
No cpmmect comes up it not reading the disk at all
这个答案有帮助吗?
得分 0
2条评论:
Yow men, i also disassembled my PS4 Pro. I follow each and every step on a youtube video tutorial. I never missed one. After cleaning it, i assembled it again, tried to open my PS4 Pro, now it says, unrecognized disc. What do u think is the problem? I dont think i broke something because im careful as fck.
完成的
Did you find a solution. I opened mine as well and now it is not reading any disc
完成的
添加一条评论
So basically my PS4 is driving me &&^&^$^ crazy with all its $@$*!& &&^&^$^ hardware AND software not to mention it; turn on and back off by itself from time to time, it just shuts down by itself while in game, the disc ejects by itself, unrecognizable disc, it just doesnt stop reading and a bunch of &&^&^$^ software ERRORS TOO cheap SONY CRAP once again time to switch up.
这个答案有帮助吗?
得分 0
添加一条评论
did you try this?:
https://appuals.com/how-to-fix-ps4-plays...
这个答案有帮助吗?
得分 0
添加一条评论
Turning it vertically worked for us! Thanks
这个答案有帮助吗?
得分 0
添加一条评论
My PS4 doesn't eject disks, but after doing manual eject it says disc unrecognizable… please help how do I fix this…
这个答案有帮助吗?
得分 0
添加一条评论
All you have to do is turn off your ps4 for 10 minutes then turn it on
这个答案有帮助吗?
得分 0
1条评论:
Sure, will help all the problems xd.. its a problem with the laser, reading the disc lol.. Tap it when u load a disc and it works. turning it on 10 minutes after will just waste 10 minutes of your time :)
完成的
添加一条评论
If tapping it doesn’t work, replace the laser. If it does work, then it probably needs a new spinner or new magnet.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jordan 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 136
总计 69,523
