跳转到主内容
加入维修社区 - 创建账户
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
I am getting F09 error code
while in the rinse cycle I am getting an F09 error code. What is it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
There was a penny inside my water pump. Follow the instructions on how to check the inside of your water pump and you will likely find the problem.
完成的
添加一条评论
3个答案
已选择的解决方案
The F09 error is a water pump problem, either clogged pump, or pump malfunctioning, Check for something clogging the water pump. To do that, open the lower access panel by unscrewing the 3 torx screws at the very bottom of that panel, then you will see the plastic water pump in the middle front, just unscrew the handle, get a few dry towels as some water will come out.
这个答案有帮助吗?
得分 9
7条评论:
You may want to unplug it first before you begin.
完成的
Thank you very much. I pulled a wad of gunk out of the pump housing.
完成的
Glad I could save you a service call ;-)
完成的
Thank you so very much! You have helped us to help ourselves and saved us the needed money. Thank you so much . :)
完成的
Thank you! That was exactly the issue we came across last night. The directions were perfect, found one of my daughters hair ties, a rather broken up Lego brick and some hard water calcified build up (we had installed a water softener some years ago, so this may be some "historical" break up). Ran a load today and no code, no issues.
完成的
显示更多的2条评论
添加一条评论
hi i have f9 display always when i start machen can you help with this
这个答案有帮助吗?
得分 1
添加一条评论
We have also been getting the F09 code but only on Delicate cycle, not on Normal cycle... It does it 5 minutes before the end of the cycle and will only move forward if we turn it off and then back on. It then runs the remaining 5 minutes.
这个答案有帮助吗?
得分 0
1条评论:
I too keep getting this code in the exact same manner you describe. Did you ever find out why? (we just had Sears repair out yesterday and replaced the pump)
完成的
添加一条评论
添加你的答案
Tim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 73
总计 33,116
