跳转到主内容
The T-Mobile G1 is the first smartphone to be marketed running the mobile Android operating system. Released in September 2008.
6 个问题 查看全部
Why did the phone stop getting a signal?
Recently my phone stopped getting a signal. Having no memory of dropping it, bumping into something with the phone in pocket, or placing it near any liquids, I can't figure out why the phone says "No Service". Accessing Settings>Wireless Controls>Mobile Networks>Network Operators, and selecting "Search Networks" result in finding either AT&T or no carrier at all. However, tapping the bottom right corner of the phone (Front Side) gently, on something such as the inner part of the knee, sometimes enables the phone to acquire a network connection. Strangely, placing a call while the phone is connected to a network will put it back in the "No Service" state after only a few seconds, while texting or simply leaving it be will allow it to remain in service much longer. Is there a solution??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
6条评论
No such thing as "jailbreaking" for android. You can, however "root" your phone, but that's a completely different thing. Android doesn't need to be "jailbroken" it's just open to begin with. And there's a reason why they call it the T-MOBILE g1
完成的
rab, that's not true. Android isn't completely "open" as you say!! and just to inform you, the term "jailbreak" is also "rooting". All jailbreaking does is allow Root access to the System.
完成的
If it were completely "open" as you say, there would be absolutely no need for "rooting".
完成的
Sure, you do need to root to do somethings, but everything you jailbreak on iOS to do you can do right out of the box on android
完成的
Well, either way Rab, you have to "root" both platforms to get full access to the system.
完成的
显示更多的1条评论
添加一条评论
4个答案
最有帮助的答案
While this may sound like a hardware related problem, we must also look at the software side. What you're describing sounds like an issue with the radio. Is your phone rooted? If so, are you running a custom ROM? It could be that you're running an incompatible radio and it's causing issues with your signal.
这个答案有帮助吗?
得分 4
1条评论:
Good answer. People are quick to shoot answers without asking the proper questions first. +
完成的
添加一条评论
Try a new sim card, whenever I've had a problem like this it's because the SIM is bad.
这个答案有帮助吗?
得分 0
4条评论:
完成的
I did not mark any comments as such, I have no idea what you're talking about. Why the downvote?
完成的
I didn't. Not my style... You have to be rude or very wrong to get a downvote. In mod it says you voted a comment spam/offensive from ab.? I see he deleted his comment about jailbreak so maybe he sorted it out.
完成的
No, I don't remember ever voting a comment as offensive
完成的
添加一条评论
Jailbreaking is done to 1. Unlock the bootloader so that unsigned system code (other OSes, iOS downgrades) may be run, 2. Enable sideloading of applications from sources outside of the iOS or other "app store", and 3. Gain UID 0 (root) access.
On Android, "rooting" is almost always #3 by itself. The vast majority of Android phones already have bootloaders that will happily load kernels and OSes not cryptographically signed by the device manufacturer. In the few cases they are "bootloader locked", unlocking can often be done simply by using an official utility from the device manufacturer. Just as well, the vast majority of Android devices have the capability to install sideloaded applications. "Enabling" this feature in these devices is as simple as checking a option in the system settings. In short, we distinguish "rooting" from "jailbreaking" because "jailbreaking" always encompasses all three whereas "rooting" rarely involves anything outside of #3.
这个答案有帮助吗?
得分 0
1条评论:
I have an IPhone 6S Plus, where and what is the bootloader?
完成的
添加一条评论
My phone quit getting signal and went to no service a little over 3 hours ago, my fiancé and I did everything we could to figure out why but we cant
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 10,770
