跳转到主内容
The Early 2009 Mac Pro—also known as the Mac Pro 4,1—introduced Intel's Nehalem architecture to Apple's line of professional desktop computers in March 2009. The Mac Pro 5,1 used the same interior design but received further CPU updates in 2010 and 2012.
202 个问题 查看全部
Installing a WiFi Combo PCIe card on my Mac Pro mid2010
Hi guys.
I bought a WiFi PCI-e card for my Mac Pro mid2010. It doesn't work even on Bootcamp Windows 10. The problem is that it came with a power cable which I assume should be connected to a USB pin on a PC motherboard, but as much I searched on my Mac logic board, it does not contain any of such pin. Do you guys think I can use a SATA power port, like the one available for SuperDrive? I appreciate your instruction.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
1st no need to power this wifi
2nd use internet from other computer install wifi card in pcie extn. Put in slot. Then start pc . It will be automatically install software driver frm net.
3rd configure if u habe any password
Then chk terminal with command of config if i think which ip address use this card that it.
You r done
这个答案有帮助吗?
得分 1
添加一条评论
Not sure why it needs power as the PCI slot offers it.
In any case the connection on the board implies its looking for USB power which is 5 Volts at 500 mA (0.5 A) for USB 2.0 and 900 mA (0.9 A) for USB 3.0. So you'll need to find a source within the system to supply that or use an external USB power supply.
Is there a reason you didn't just use the built-in Airport port on the main logic board?
这个答案有帮助吗?
得分 0
2条评论:
How can I do that? The board on PCI-E is much smaller than the Airport Slot on my Mac's logic board. Also, its original Airport is 802.11n while this one is ac. I wonder if Mac doesn't detect it, how come Windows 10 (Boot Camp) doesn't as well? I tested it on another PC and it works fine. Of course on PC, I connected it to a USB pin on MB.
完成的
添加一条评论
I don't know if you ever got this figured out or not. But, I was having this problem as well. I finally found an answer. You can use that card, instead of a mini-PCIe card if you want to. You do need BT Data. That's the cord coming off of the card labeled USB Data-/Data+. From my understanding, it is not a power source you need, but you need the Data connection for Bluetooth.
I just realized your card might be Wifi only. I see that you have 3 antennas, whereas mine has 4: 1 for BT, and 3 for wifi. I thought from the "Combo card" in your title that it was a Wifi & BT Card. However, I don't know why it would need Data -/+ if it wasn't BT also. Which is it?
If it is a BT & Wifi like mine, you can use the original BT MoBo header for the data-/+ that you need. you need Do an adapter/new plug to plug into or you can splice the wires into the original BT data cable. the original BT header (next to the BT Card) uses a tiny 4-pin connector, of which you'd only use the top two pins for the Data. Top is Data-, 2nd from top is Data+
Otherwise, if it is wifi only, maybe you could remove the card from the PCIe adapter and see if just the card fits in the mini PCIe slot the original wifi card came in. It looks like the actual wifi card is installed on the PCIe 'sled' in a mini PCIe slot.
These are just my thoughts and suggestions of what to consider. I am by no means an expert on this and learning as I go, while trying to upgrade my 2010 MacPro. You probably have already resolved this problem, since this thread is several years old, anyways. I am dealing with the problem now, hence me stumbling across this post.
Good Luck & God speed!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bob Mavric 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 20
总计 1,080
