跳转到主内容
Guides and support for various television (TV) brands and styles.
9059 个问题 查看全部
Bush TV stopped working - No power
Hi everyone,
My Bush TV (LED24127FHDDVD) randomly turned itself off with no indication of any problems prior to it happening. I've had it a couple of years and not had any problems whatsoever.
Usually the standby light turns on when it is plugged in but that doesn't even appear anymore.
I've replaced the fuse in the plug but that did not make any difference. I'm assuming it may be a problem with power but I am not entirely sure.
I have attached pictures of the circuit board at the back of the TV- any help in the matter would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
My Bush lcd32tv016HD 2007 vintage, kept turning off with no standby light. I fixed it by viewing the power board soldering with a x10 hand lens and found lots of cracked solder joints. With a soldering iron, solder and flux, the solder can be melted to repair the joint. Also did this on the logic board where the power comes in. Basically anywhere where there is lots of heating and cooling, the solder eventually breaks either at connections or hot chip. Also replaced an electrolytic iffy capacitor (smd 10uF 16v esr38Ohm) but not sure if that was necessary.
这个答案有帮助吗?
得分 2
1条评论:
How to repair cold solder joints
https://www.youtube.com/watch?v=VLubdi6a...
完成的
添加一条评论
添加你的答案
Tester1331 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 35
总计 6,585
