跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2266 个问题 查看全部
iPhone 7 No front camera plastic holder/bracket/clip in replacement
Hi all,
I'm currently in the process of replacing the screen on my Iphone 7. Starting to reassemble the front camera and noticed that the replacement screen doesn't have the two plastic holders/brackets for the front camera and proximity sensor (see link) like my old screen does. Is this going to be a problem? Is it possible to transfer them over from the old screen (they seem to be stuck on there pretty tightly...)? If I have to purchase these how do I attach them, would an adhesive of some kind be necessary?
Thanks in advance
In case you don't know which parts I mean!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
You could try to reassemble the Front Camera flex without these brackets to see if everything lines up correctly (test the sensors). The risk is that as the phone gets jostled or dropped, the sensors and camera may move out of alignment.
You can order the brackets separately and stick them in place with a tiny drop of liquid adhesive. You need to make certain that the adhesive doesn't get on the window .
这个答案有帮助吗?
得分 1
添加一条评论
Use an isesamo to carefully pry those off. Heat on the front side of the screen may be helpful.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kyrra Rhyannon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 421
