跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Back Camera + Flashlight don´t work
Hello,
i have bought an Iphone 7 128 gb black where the seller says the back Camera is not working. So when i get the Iphone i checked all and all worked, only the back Camera and the flashlight for it don´t work. (Face time Camera works well)
I replaced the Camera with a working camera from another iphone to test it and have also the same problem. I take the motherboard also into another iphone to test if there is something wrong with the flexcable on the back, but nothing changed.
So is there a chip or something else who turns the light and camera on?
kindly regards from austria.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
There is a chip on the motherboard that controlls the camera and flash. you will have to replace that chip to get the camera working, it is a very difficult process with high risk for first timers.
完成的
Hello, do you have a pic where i find this controller? regards
完成的
The camera and flash uses different chips,DA3 chip controls the flash while SN61280D controls the Camera. It's a 16 pins connector chip.
完成的
添加一条评论
1个答案
已选择的解决方案
There is some circuitry responsible for powering the back camera and flash, this may be what's at fault here. I'm not clear on which motherboard you tried in which phone (lost in the translation ;>). Have you tried a known working logic board in the phone that has the flash and camera issue? If you have and the problem is still there, then your flash flexand camera may be damaged. If the replacement logic board works then your problem is on the original logic board and this will require a micro-soldering repair.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Josef 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 5
总计 20,982
