跳转到主内容
Repair guides and support for a wide range of small engines.
103 个问题 查看全部
Will this engine still run?
I have an old engine from a Craftsman push trimmer. Probably from the late 90's. The piston decided to break and go through the camshaft wall. I'm wondering if I replace the piston if it will run with the hole still being their.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Pistons create compression that then gets ignited, In a closed cylinder that forces the piston down which rotates the drive shaft. With a hole in it, you don't get enough compression to force the piston down, it just blows out the hole and your engine doesn't run. For example, you can still sometimes breath when you get a hole shot into a lung (Pneumothorax) (sucking chest wound), but the lung quickly collapes. In your case, fire will shoot out the hole, probably igniting the gas or oil. That creates a sound similar to this: https://www.youtube.com/watch?v=iWtohHwN...
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
JIM BOB 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 45
