Why my laptop not starting, it's says internal hard disk drive not fou
My laptop says," internal hard disk drive not found. To resolve this issue, try to reseat the drive."
Please help me with this. What must I do?
simphiwe ntshangase this sounds like a bad hard drive. Hit F2 on startup and check to see if your drive still shows up in the BIOS. While you are there set your boot order to optical drive or USB drive. Then exit. Now you need a bootable USB or CD. Place that into the drive you select in the BIOS (CD or USB) and see if your computer starts up. If so you know that you most like have a failed drive.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 345
6条评论
did something happen? or did fix it recently?
由 Aiden 完成的
No it did this just today
由 simphiwe ntshangase 完成的
is it making any weird sounds?
由 Aiden 完成的
Yes it is. It says, No bootable devices--strike F1 to retry boot, F2 for setup utility
Press F5 to run onboard diagnostics
Are you there Aiden Baker
显示更多的1条评论
