跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Trackpad works but haptic feedback not there
I bought an early 2015 macbook pro second hand and the trackpad works and the mouse will click but the haptic feedback isn't doing anything even with it enabled in the settings. The guy I bought it from is not responding to me when I asked for a refund so I'm looking to fix it myself now. I took it in to the store and all they could do was determine it was a hardware issue and will either charge me $90 to replace the cable which I know I can do myself or $400 to replace the whole topcase. What are the chances that replacing the cable will fix the issue so I hopefully don't have to replace the trackpad?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I can confirm that the cable might be the issue. I had apparently damaged the cable during a battery replacement with no visible damage. After reassembly, the trackpad was working fine but no haptic feedback. I swapped out the cable for a used one and everything worked just fine.
hope this helps someone
完成的
添加一条评论
4个答案
已选择的解决方案
Are you a betting man?
The cable is known to have issues! I personally haven't seen the haptic feedback as a failure of the cable, more likely the trackpad. Thats not to say the cable still could be bad here (just less likely).
Here's the IFIXIT guide to replace the trackpad: MacBook Pro 13" Retina 显示屏 2015早期 触摸板更换 which is where the haptic unit is part of. Here's the trackpad with the cable Retina MacBook Pro 13" Trackpad & Cable.
It's a lot less expensive than replacing the complete uppercase.
这个答案有帮助吗?
得分 1
3条评论:
Thanks for the quick response. I ordered the cable and should be able to swap it out this weekend. One question I have about replacing the trackpad is the adhesive on the battery. Once I've removed the battery and replaced the trackpad where would I get replacement adhesive for putting the battery back in?
完成的
Boy! You want all my secrets ;-} Now this is between you and me right?
Once the old adhesive is fully removed, I use 3M Stretch Release Tape Here's the data sheet: Double Coated Stretch Release Tape 6657-150. We ordered a case of it 1" wide about two years ago from Tekta. The trick is to leave a tail that you can grab to make it easer to replace the battery later on.
完成的
Thanks a lot for your help. I've now replaced the trackpad and it's working great!
完成的
添加一条评论
Have you tried resetting the PRAM? Command-Option-P-R on startup. I was able to restore Haptic feedback on my MacBook Pro when it stopped working out of the blue using that startup command.
这个答案有帮助吗?
得分 0
添加一条评论
I want to echo something that Dan said.
I went and bought a replacement cable from Ebay for about $13 AUD. It was a bit longer and had more slack. The part was not a genuine Apple part. It worked 90% of the way just like you said, but the haptic feedback was not there.
Unfortunately I had work to do and didn’t want to waste anymore time. I went to apple store and they immediately agreed it was a trackpad cable issue. They charged $15 for the part and $120 for labour. They actually did the job first to confirm & identify that was the issue (without requiring me to deposit my laptop and put it in a queue for a week). It worked.
So long story short. Small things on ebay despite same part number are unlikely genuine. Same on iFixIt, Louis Rossman Repair, and most other sites - specifically if they claim new condition. Only Apple sells genuine parts and not to the public.
You can however buy used parts that are genuine. Powerbook Medic is good for this.
Anyway this is an unfortunate situation. I expensed the repair on my company dime since I use it exclusively for work despite it being personally mine. But I understand not everyone can do this and so I hope someone will find it helpful when they look for the trackpad cable replacement to know that there is actually a difference between a genuine and a non-genuine part. Which sucks.
这个答案有帮助吗?
得分 0
添加一条评论
I just want to add that I cleaned the contacts of the taptic engine (copper wire wrapped thing screwed with x2 T3 screws on the trackpad itself) and taptic engine contacts itself on the trackpad with 80% alcohol pads and that fixed the issue
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Josh Doan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 29
过去 30 天: 131
总计 23,526
