跳转到主内容
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
Not all of the trackpad is clickable
So ive noticed on my personal machine that i cannot click anywhere on the edge of the trackpad i have to click at least 1cm in from the trackpad in order for the force touch to even click, for example i cant even right or left click right in the corner this doesn't happen on the 13 inch im just wondering if this is normal as most of the time im using a bluetooth mouse.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
You may need to visit a store which has one on display to verify. For some reason I think thats right the click area is not to the edge.
Apple is pushing to the touch mediphor like the newer iPhones. So now you press and hold to gain access to the right click menu.
完成的
The MacBook Pro trackpad is not all clickable I have one. 80% trackpad is clickable.
完成的
ah well I'm glad I'm not the only one I hope this might be fixed at some point now that I've noticed it, its really annoying
完成的
@danj it happens with both left and right I just stated right as thats most difficult as you naturally click in the bottom right
完成的
添加一条评论
3个答案
最有帮助的答案
Check with Apple to see if this is covered under their new program.
Keyboard Service Program for MacBook and MacBook Pro
https://www.apple.com/support/keyboard-s...
这个答案有帮助吗?
得分 3
2条评论:
i popped it into them today, they refused to do anything, i checked all the devices in the store and around 7 of them had the same issue however some of them didn't, at first i thought it was all devices.
完成的
Contact Apple directly at 1-800 MYAPPLE
完成的
添加一条评论
I had the same problem.
Apple actually changed my trackpad/keyboard 3 times in a row before realising they couldn't do anything.
They then understood it was a broader problem affecting all new 15'macbook pro.
They explained to me that the haptic feedback does not cover the whole area of the trackpad. There is no fix.
这个答案有帮助吗?
得分 2
添加一条评论
Compared to the ones I've seen in store, the whole trackpad should be clickable? Even if half of your finger is off one side, it should still be able to be clicked? I would definitely try and take it into a store if possible and compare/get them to repair it for you.
这个答案有帮助吗?
得分 1
1条评论:
It appears on all or most of the 15 inches ive had the trackpad replaced twice and a new machine they say theres nothing they can do and its normal which it clearly isnt
完成的
添加一条评论
添加你的答案
lewis Barker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 1,779
