跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
upgrading to a SSD
I have 27" Late 2009 iMac.
Can I replace original 1TB HDD with 1TB SSD?
Update (03/24/2018)
My only lingering worry is how to handle temperature sensor for the HDD.
Obviously SSD will not have temperature sensor, so what should I do with the temperature sensor for HDD?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
There is external sensor on the kit to put it on top of ssd.
完成的
添加一条评论
2个答案
已选择的解决方案
Sure you can! Follow this IFIXIT guide: iMac 因特尔 27" EMC 2309 和 2374 硬盘更换 and here's the needed tools and parts: iMac Intel 21.5" and 27" (Late 2009-Mid 2010) SSD Upgrade Kit
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 21" and 27" Late 2009-Mid 2010 with this SSD upgrade kit.图片
产品
$122.99
这个答案有帮助吗?
得分 2
添加一条评论
Yes you can do it if you can afford it,
But the 1 tb SSD will be little expensive and a caddy to fit it...
You can buy a smaller ssd and a dvd to hdd caddy and replace the dvd with new ssd (depending on your time)if you are not using the dvd any more...
这个答案有帮助吗?
得分 0
3条评论:
Actually the one iFixit was selling (out of stock now) was not that bad on price: [关联产品丢失或禁用: IF107-132]
完成的
The kit cost for a 1 TB is $389.99
完成的
Yes , iFixit prices is good , and the 500gb ssd kit is in stock!
You can make you old one Usb external.... and keep your dvd drive!
完成的
添加一条评论
添加你的答案
ikim20012 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 583
