跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Cellular service reset loop.
My iPhone 7 started acting strange just recently. The cellular service data bars seem to loop every 15 seconds. At the end of the 15
seconds, it show full bars, go back down, and will occasionally say no service. I’m quite familiar with how to fix iPhones, but this is the first time I’ve had an iPhone 7 and with this issue. Images will be included.
EDIT: The connection is stable and uninterrupted when I'm talking on the phone.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Phone calls usually use 3G, but while not in calls 4G / LTE is usually used.
To get an issue like that fixed, chances are you will have to take the phone to someone that does board-level repairs / microsoldering.
这个答案有帮助吗?
得分 2
2条评论:
Any clue as to the estimated cost?
完成的
it cost from 80 up to 120 for the no service/searching issue.
完成的
添加一条评论
添加你的答案
Erick Villa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 81
