跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2266 个问题 查看全部
iPhone 7 Stuck On Apple Logo / No Booting
I have an iPhone 7 jailbroken with match portal. I was using my phone and it randomly shut off and it is stuck on the white apple logo. I have tried restarting the phone multiple times holding the volume down and power button but it goes right back to the Apple logo. iTunes does detect the iPhone but it says I need to enter in my passcode to access it which I can't. I don't have money to go to workshop. Any help (ifixit guide/tutorial/video/tips) would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
Hey asik,
I have this same problem. I have a red iPhone 7 but it is always stuck on black, and when I try to turn it on it stays on the apple logo loading screen.
I took it to Apple INC. and they couldn't do anything, they kept sending me to random places that could "Fix your phone" but it never worked, i ended up buying a brand new iPhone 6s cause the older models work better.
I suggest you get a new phone or something.
- Hazey
这个答案有帮助吗?
得分 0
添加一条评论
You could always try to wipe the device remotely with “Find my iPhone“ and another Apple device that is logged in with the same Apple ID as your phone.
If that doesn’t work, hook it up to iTunes on a computer. Enter recovery mode by holding in the power button and the volume down button. Keep them that way until your phone has entered recovery mode. You can now release the buttons and iTunes should detect the phone.
iTunes will give you 2 options: update or restore. Choose update, and iOS will be reinstalled without getting your data wiped. Your phone will hopefully work after this.
But I recommend you to read Apple’s Help Support about problems like this to get the best answer.
Have a good day.
这个答案有帮助吗?
得分 0
1条评论:
EDIT: Altough this question is old, I do recommend you to try it if you still have your old phone. You might be able to retrieve your lost data.
完成的
添加一条评论
添加你的答案
Asik Omer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,487
