跳转到主内容
Released in 2010, the Logitech G27 is an electronic steering wheel designed for Sim racing video games on the PC, PS2 and PS3.
44 个问题 查看全部
Buttons on steering wheel not working, do you sell replacement wires?
I have a Logitech G27 racing wheel, the buttons and the shifters on the wheel it’s self have stopped working, I have pin pointed the problem being the wire that goes from the wheel to the base of the wheel, do you sell these wires or components?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Maybe a bit late, but this might help someone else coming across this question. You probably won’t be able to buy a assembled wire, however if you can find someone or learn the skills required to assemble it it should be easily replaceable. Most individual wires you can either get from a electronics/hardware shop, probably AWG 18 or 20 though I’m not entirely sure what size they are. Its more important that they fit in the crimp housing/socket, rather then a specific size otherwise.
You’ll also need to find some crimp wire housings/sockets to crimp on the wires (after stripping), you can find some on Farnell, Mouser or other similar component suppliers. The most tricky part will be finding one that will fit and stay in the housing, here’s a example one for reference (though I haven’t checked it’ll fit). See here for wire stripping and crimping: https://learn.sparkfun.com/tutorials/wor....
Depending on whats broken you might also need some heatshrink to cover the wires and keep them together. If your not comfortable with all of this I’d suggest seeking out someone more familiar with electronics/wiring.
这个答案有帮助吗?
得分 0
1条评论:
Couldn't you just buy a broken g27 thats for parts and use the connector from that?
完成的
添加一条评论
You can get supplies like this from Mouser Electronics
https://www.mouser.com
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel williams 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 23
总计 1,329
