跳转到主内容
Repair guides and support for USB flash drives, also known as jump drives, USB sticks or thumb drives.
48 个问题 查看全部
Where Do I Solder on my SanDisk Cruzer Dial so I can get my stuff?
Recently, I was using my 32GB SanDisk Cruzer Dial in my laptop. I put the laptop in my bag and later that day, I realized that I cracked the PCB near the USB connection pins. I talked to SanDisk, but they said I need to get a new one.... NO!
So which points on the PCB do I solder to so that I can solder an alternative USB to it? A guide with pictures would be helpful. Thank you in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
how do you get to the circuit board
完成的
添加一条评论
2个答案
已选择的解决方案
USB are relatively simple devices when it comes the the USB connector. A close inspection of the pcb should yield all the clues you need to solder either a replacement USB port or extend jumper wires to the existing one.
If the pcb broke in an area with a higher density of traces, the repair may be more complicated. It would certainly help if you could post some pictures of the usb drive so that I can see for myself.
Erkin has several videos of USB Drive repairs. You can take a look at those to see if that helps you.
这个答案有帮助吗?
得分 5
5条评论:
I don't know which wires to solder to which points...
完成的
The you should consider sending the flash drive an experienced micro-solderer. They should be able to fix this so you can get your data out.
完成的
OK, could you use one of the pictures I have provided and mark which point is what? Like I remember with my 3ds, a tutorial saying where CLK and GRND and all of those were.
完成的
Oops, I didn't upload the images. There you are.
完成的
use multimeter for mesure 4 pins of usb connector 5V D-/D+ GND to see which one without value that what you looking for broken trace.
完成的
添加一条评论
@refectio mine is like this
How can i solder VCC and GND if the conector is broken like this?
这个答案有帮助吗?
得分 0
3条评论:
First you need to practice on another small item to learn how much heat it can handle before burning the rest of the trace off of the PCB, this is the biggest problem is beginers. All you need to do is get a piece of copper wire and jump it from the top left red circle to the bottom left red circle and the same for the right side, dont let the copper wires touch, you only need a single very small wire strand, not a complete multistrand cable, very delicate work, once you transfer the data, toss this one in the trash, next time buy 2 of the same USB and keep one for spare parts if you need to swap over the memory chip, this work will be done by a cell phone repair guy who knows what he is doing for sure.
完成的
Well said Duane.
完成的
@refectio Good to see u around :)
完成的
添加一条评论
添加你的答案
Tyler Meece 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 32
总计 2,938
