跳转到主内容
加入维修社区 - 创建账户
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Trackpad Replacement not working
I recently replaced the trackpad in a 15" MBP - Early 2011 and it seemed to be working great. However, no its working very intermittently, sometimes it tracks as I would expect other times the pointer doesn't even move.
Any ideas? Is this trackpad defective? If so how do I return it and get a different one???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Check to see if your battery is swollen. If you can't tell, remove the battery and start up with just the mag-safe adapter and let us know if the issues persists.
这个答案有帮助吗?
得分 2
3条评论:
I replaced the battery as par of the repair. I completely removed the battery and replaced the trackpad because the brackets had become bent with the last battery swelling so large.
完成的
Check to see if the old battery has bent upper case. Did you also replace the trackpad cable?
完成的
Top case looks good. Yes, replaced everything. Battery, trackpad, cable, screws, brackets. Its very odd. Sometimes it works great, other times not so much. very intermittent.
完成的
添加一条评论
If you're certain you installed correctly, assuming the part is from iFixit, yes, you can get a replacement for a defective item. iFixit offers lifetime warranty against defects for non-consumable items. Hope that helped! (If you have questions about iFixit returns, post them on meta.ifixit.com, not here)
这个答案有帮助吗?
得分 0
2条评论:
Thanks, I threw that last part in just as a, "if no one else has good options then I will need a swap" kind of comment. Thanks for the link though.
完成的
@cssd11tech No problem! Hope you solve your issue!
完成的
添加一条评论
添加你的答案
Jason Reynolds 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 218
