跳转到主内容
The DJI Phantom 4 Pro is a smart flying camera with forward and rear obstacle detection sensors and 28 minute flight time. It also features a better camera and every angle besides the top of obstacle avoidance.
10 个问题 查看全部
Little access door on one leg
I accidentally ran into a tree branch in the yard and it made the phantom 4 stop and it fell about 6 feet. One of the propellers were broken but I replaced that. A little access door on one of the legs popped off and it is not wanting to snap back on. I have tried but get to the point where I am afraid to force any more for fear of breaking it. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Be sure the landing gear isn't broken at the leg where the screw cover came off. Sounds like the leg may be bent a little which is causing the cover to not fit properly. It should snap in after inserting the prongs into the bottom of the opening (with the drone right side up - top of the opening if it's upside down).
这个答案有帮助吗?
得分 0
1条评论:
Have same issue how do you bend leg back to close it properly? It goes back in place when you pull a little on the leg but don't want to break leg fell like plastic that may snap.
完成的
添加一条评论
添加你的答案
Pam Emelio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 447
