跳转到主内容
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 个问题 查看全部
How do I fix a broken power pin?
Alright. Long story short. I got this used from a friend. In the process of cleaning I found the metal "pin" for the touch sensor broke off.
Could I solder a piece of metal to it or will it be cheaper to replace it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
it wont be cheaper to replace, but it will be better to replace, as it looks quite dirty and you do not wanna be going back and forward having to fix the power, it is better to fix it the correct . way the first time with the new part,solder and a soldering iron.
这个答案有帮助吗?
得分 0
2条评论:
It's a CECHK. I recently dismantled it for cleaning. I also found that a piece of aluminum foil can serve as a pin.... though, I'm not sure how well scotch tape will hold up in the long run....
完成的
yes he wants to try the foil, but like i stated as well durability i cannot speak for, and you just solder the pins back together if you have the original . pieces with a soldering iron and solder.Most jobs are done under microscopes etc , so that will depend on your tools, your eyesight, etc.. if pads are torn will need some extensive knowledge to rebuild the trace. if you dont know how and dont want to spend the money to have it professionally done you can try the foil as @astro_ will bosco suggested
完成的
添加一条评论
添加你的答案
Will Bosco 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 146
