跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
Touch screen crazy behavior
Hello , I´ve a serious problem with my Iphone X , the tactile interface creates random clicks on display. For example if I manage to open the calculator some numbers are not working and in other moments start to type ramdom numbers 88789383... and do on. I´m not sure if the problem would be fixed replacing the complete display assembly or I need to replace other parts.
Regards, Patricio.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
The display is the likely issue here however given that your phone is surely still under warranty, I would suggest you have it replaced by Apple.
If your phone shows any signs of physical damage, they may refuse to to change the screen in which case a reputable third party repair shop can help you out or you can try it yourself.
这个答案有帮助吗?
得分 5
1条评论:
I'm having. the same problem and asked for a replacement and is doing the same thing, I can only think is that your part is not fully comparable with my phone I'm going to ask for a refund .
完成的
添加一条评论
My phone had become very glitchy. It would type random numbers or change screens on its own or wouldn’t recognize a touch. After calling Apple three times and going to the Apple store twice, they determined I needed a new display. Since it was still under warranty, there was no charge. So far, problems been solved.
这个答案有帮助吗?
得分 0
添加一条评论
I've got an Iphone X, the screen was going crazy opening random apps, impossible to type, etc. I was ready to smash it. I went into display settings and turned off True Tone-it seems to be fixed!
这个答案有帮助吗?
得分 0
1条评论:
Why would of that fixed it?
Your only changing the colour of the screen
完成的
添加一条评论
添加你的答案
patriciogreco 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 31
总计 66,865
