跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Doesn't turn on after disassembling for dust cleaning
Hi,
It is not the first time I disassemble a computer. I have done it many times with my MacBook Pro.
But this time, I have done it for the first time on a Macbook A1181. I followed this guide to access the fan: MacBook Core Duo Fan Replacement
After reassembling the computer doesn't respond when I press the switch... :-(
I have checked the upper case cable (step 12) but it looks fine.
What should I do?
Thanks
Jerome
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Finally, I solved the problem by changing the upper case cable.
Unfortunately I couldn't buy on iFixit. I found it there: https://www.amazon.it/gp/product/B01MSH3...
And then followed this guide: MacBook Core Duo Upper Case Cable Replacement
Thanks for the help !
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
I think you hit it on the nose. Step #12 MacBook Core Duo Upper Case Replacement
That connector can be tricky.
To confirm, try disconnecting the battery and mag-safe adapter. Press and hold the power button for 10 seconds. Reconnect and see if you get a spontaneous reboot.
这个答案有帮助吗?
得分 3
1条评论:
I did what you say. Unfortunately, it didn't change anything.
完成的
添加一条评论
添加你的答案
poissonjerome 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 242
