跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
What is Q2700Q2701 on iPhone 7
Hye, im wondering what do the Q2700/Q2701 do ?
If this two transistor is gone, is it can cause the IPhone 7 to boot up normally ??
If yes.. Can i just make jumper on this Q2700/Q2701 line ??
When I see the schematic on ZXW it showing like a bridge to transmit the data to the PMIC (correct me if im wrong). Cuz i have an IPhone 7 regarding for this issue
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
These are part of the PP_ACC_VAR rail, which is the accessory power circuit. In other words, if you connect something to the lightning port that requires power, this is the circuit that will supply it. Q2700/2701 are MOSFETS connected in parallel to allow increased current to flow while using a smaller package size. U2701 is a comparator and it is being used to monitor the output of PP_ACC_VAR and switch the MOSFETS.
Why do you believe these transistors are faulty? Even if they were, I don't believe they would stop the phone from booting.
这个答案有帮助吗?
得分 3
6条评论:
The first time i do is changing tristar and its boot up normally but cannot charge. So i tought maybe im not solder the tristar properly, so i try to reball back the tristar and when I want to put the tristar back the MOSFET suddenly gone ! Because of my shaky hands hmmmp. And now the phone not boot up normally, thats why I thought maybe the transistor faulty but im not 100% pointed to the transistor.
In my country is very hard to find this transistor. So if I make a jumper on the Q2700/Q2701 is it make sense to let the current flow ??
完成的
In that case, you'll want to remove both transistors and short B1 to A2/B2.
完成的
Having same issue. Damaged both mosfets when doing Tristar replacement. What do you mean by short B1 to A2/B2? Create a jumper between them?
完成的
Yes, just create a jumper between those pins.
完成的
Hello, the jumper its in
Q2700. B1 And A2
Q2701. B1 And b2
I lost one too
[image|1817828]
At this way?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Azim WHITE 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 3,736
