跳转到主内容
My phone keeps touching things by itself and I'm not even touching it.
This has been happening a lot lately and it is getting really frustrating. I haven't changed my screen or anything and I've had my Moto G4 for about a year now. I haven't dropped it from high up or anything and the phone is in great condition. Somehow, most of the time I pick up my phone to use it, the phone will start touching and opening random apps or start typing things when I'm trying to send a text. Can someone please help. I'll appreciate it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 49
36条评论
Can screen protect be the course too?, CU's after putting a screen protector on my phone yesterday after noon it starts operating it self this night please some one help me,am using Lenovo p1
完成的
i have a ZTE max phone buut I've had it less than a year and its really making me mad
完成的
My itel s15 keeps pressing itself without me touching it
完成的
I have this problem and I tried removing my screen protector and cleaning it and it’s the same
完成的
Hi all, thanks for information. I checked screen protector and different things.
I even reset my whole phone nothing worked so in the end I just bought a new phone. Hope the ones who having same issue can find out the cause and get it sorted.
完成的
显示更多的31条评论
添加一条评论
9个答案
最有帮助的答案
@boiiii start by making sure you back-up all of your files. Then do a hard reset. Here are some instructions:
It is highly recommended that you complete a backup of the device information and disable Device Protection before proceeding with the steps in this tutorial.
With the device turned off, press and hold the Volume down key.
Note: If Device Protection is not disabled, the login credentials for the Google account currently associated with the device will be needed to set up the device after the reset.
With the Volume down key held down, press and hold the Power key.
Release both keys when the Android screen appears.
Use the Volume keys to scroll to RECOVERY MODE.
Press the Power key to select RECOVERY MODE.
When the No command message appears, press and hold the Power key.
While holding the Power key, press and release the Volume Up key.
Note: Release the Power key when the Android Recovery screen appears.
Press the Volume down key to scroll to Wipe data/factory reset.
With Wipe data/factory reset highlighted, press the Power key.
Press the Volume down key to scroll to Userdata only, then press the Power key.
Once the wipe is complete, with Reboot system now highlighted, press the Power key.
The device will restart.
The device is now reset and ready for use. from here.
If that still will not resolve the issue, you most likely need a new display assembly since that is where the "ghost touch" usually originates from.
这个答案有帮助吗?
得分 4
3条评论:
I tried this and there was no 'recovery mode' option...I'm using a cubot R19
完成的
I use it too,found a solution yet
完成的
it did not solve the prblem so it might be the "ghost touch" error. but the advice was really helpful. thank you
rolgem
完成的
添加一条评论
I had the same problem and realized it was only happening when the phone was plugged into the charger. I have heard them called "turbo" chargers but don't know if that is the case. It does not do it when plugged into my car phone jack. Remove the charger before you start working on the phone and it does not happen!
这个答案有帮助吗?
得分 3
2条评论:
Thanks! My iPad was plugged into the car charger, And I didn’t know why there were random buttons were being pressed when I wasn’t pressing them, This really helped!
完成的
Mine does the opposite, when plugged in to power the ghost typing stops and everything is perfect...it's worse when using FB...so annoying
完成的
添加一条评论
I had the same problem. All I did to fix it was hold down my power button and press restart after that I didn't have anymore problems. It happened after my mom hit a bear (were all safe) I started having issues with my phone but I did that and it worked again
If this doesn't help with your problem then try reading the other comments and sorry if it's not useful.
这个答案有帮助吗?
得分 2
2条评论:
Did the bear retaliate?
完成的
Well what I did is turn my phone off and on and it Stopped see if this helps!
完成的
添加一条评论
Did you try giving it a light twist, sometimes the screen gets bent, so giving a __very light twist__ can fix this.
这个答案有帮助吗?
得分 0
1条评论:
I just twisted my iphone11 I hope it works for now it seems ok
完成的
添加一条评论
iPhones and some other phones have touch sensors placed near the charging ports. If your phone acts up when charging it means the energy is messing with the touch sensors. Unfortunately this means you need a new phone.
这个答案有帮助吗?
得分 0
添加一条评论
I suggest trying a phone cover that covers, or just covers the edges of the screen. My moto E7 does this alot too, even automatically saying going to a Facebook event and typing random letters, opening apps etc.
Also try typing with fingers away from screen bottom edge, it seems to help, but may increase chance of phone dropping from hands.
If not I'd say a new screen or phone if your phone was cheapish is the best solution. Funny thing is this is my third phone with this issue (all different models and more expensive models) it may be an actual ghost or computer flaw. Weird stuff.
这个答案有帮助吗?
得分 0
添加一条评论
Hi,
Well this video may help you: https://www.youtube.com/watch?v=z29Y-AhS...
这个答案有帮助吗?
得分 0
添加一条评论
May be your account is using some one else withhas you who is takingthe these actions or maypolicies be your phone is hacked
这个答案有帮助吗?
得分 0
添加一条评论
It may be a virus or a hacker
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rahul Mohammed 将永远感激不已
浏览统计数据:
过去 24 小时: 15
过去 7 天: 157
过去 30 天: 595
总计 186,276
