跳转到主内容
加入维修社区 - 创建账户
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Why won't my dryer turn on, it shows wet status even when it's empty?
i have a Kenmore Elite Dryer HE3. The Dryer will not run after I push the start button. It just clicks off. I tried unplugging it and re-plugging it. I tried removing all the clothes to see if it will run even when it is empty. There is electricity going to the dryer and the circuit board. It just will not run.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
The outlet is 220. I already unplugged it for over 5 minutes, and I reset the breaker. None of these worked. Thank you for trying to help.
完成的
Mine also lights up and when you press start it just goes to wet signal. I unplugged it. I took all the clothes out. Still doing it.
完成的
添加一条评论
1个答案
最有帮助的答案
First unplug it for five minutes to allow it to reset. Next keep in mind that if it is being used in the USA it runs off of two 110 volt legs and may only getting one. See if you get an error code and let us know what it is.
Throw the main breakers.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
george jetson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 847
