跳转到主内容
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 个问题 查看全部
No power on after keyboard replacement.
Hi,
I just finished up with replacing the keyboard on my A1286 15 MacBook Pro. Serial no. ending in 7XK.
After doing the keyboard replacement the device doesn't turn on however the MagSafe charging light indicates that it is charging. Any ideas as to what I could be missing? This is my first repair on a MacBook so I'm very new to this...
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I manged once to get it to boot by unplugging the battery, holding the power button for ten seconds, then plugging the MagSafe in and continuing to hold the power button for another ten seconds. After which I let go and pressed the power button once.
It worked once but hasn't since then....
完成的
添加一条评论
2个答案
最有帮助的答案
You got am spontaneous rebooted by disconnecting the battery and mag-safe then reconnecting.
The first thing to check is the keyboard to logic board connector seating. See step #18 of this guide: MacBook Pro 15" Unibody Mid 2009 Upper Case Replacement
这个答案有帮助吗?
得分 2
5条评论:
I've just reseated that connection and checked the cable for any snags or marks but still to no avail.
完成的
Why were you replacing the keyboard?
完成的
The command key, back space and S key didn’t work.
完成的
I take it you spilled something on it?
完成的
I bought it second hand, so I'm unsure whether it's been water damaged. I did have a good look inside the device and none of the LCI's are triggered. But who knows. It wasn't stated when I bought it.
完成的
添加一条评论
sounds like you have a bad connection or missing connection. Go through and double check to make sure all cables are attached to the mother board correctly. did you take out the battery and ac adapter before doing the keyboard? if not it could cause a short on the logic board.
这个答案有帮助吗?
得分 0
1条评论:
Definitely took out the battery and AC adapter before hand. The MacBook has booted since the keyboard replacement after an SMC reset but since then I haven't been able to boot it up again.
I'll double check over the connections tomorrow morning as it's getting late in the UK... I did do this once before though.
完成的
添加一条评论
添加你的答案
Fraser McFaull 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 303
