跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
577 个问题 查看全部
iPad Air 1 not charging after replacing digitizer.
I replaced the digitizer on an iPad Air 1. The iPad shows that it is charging and the tone is heard when plugged in, still it does not charge above 40%. I am using an official charger and cable that works on another iPad. This is not the first digitizer that I have replaced. I have reset and downloaded the most current iSO. I followed the ifixit instructions. I am at end on what to try next. Any help will be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
I was able to find the answer to the problem. I decided to totally disassemble the iPad. Upon doing so I found that a very small piece of digitizer glass was between the battery connections. It must have went in there when I place the isolator pick in. I reassembled the iPad and now it is charging.
这个答案有帮助吗?
得分 1
1条评论:
Awesome...sometimes it takes sharp eyes to see these tiny issues!
完成的
添加一条评论
最有帮助的答案
There are a few possibilities here:
  • If you didn't isolate the battery when performing the repair, you may have damaged the charging circuit on the logic board.
  • You may have dislodged some of the small components near the battery connector. One of them (FL7500) allows the gas gauge IC inside the battery to communicate the charge state to the CPU. If that one gets knocked off, it could be causing your issues.
这个答案有帮助吗?
得分 3
4条评论:
Minho, after replacing iPad Air battery and digitizer I am having a problem charging. I suspect it could be one of the 2 problems you listed. What would be the solution to these 2 problems?
完成的
@daltmann The problems I outlined require micro-soldering repairs and are not typically DIY repairs.
完成的
Minho, would replacing the logic board fix it?
完成的
@daltmann replacing the logic board is like replacing the device. The cost is pretty similar to buying a used device.
完成的
添加一条评论
It charged fine before the replacement? Was the battery disconnected before the repair or did you leave it screwed in?
The digi would not cause the charging issue. First thing I would do is check for any damage to the battery or chargeport flex. It's easy to slip and nick these during the repair. If there is no signs of damage I would then try a new battery. If it charging at all then it's not likely the chargeport that's the issue.
这个答案有帮助吗?
得分 0
添加一条评论
Had the same problem it would only charge to 20 percent and then die.
opened it back up and made sure the battery was seated correctly and then it started charging correctly. The logic board has to seat properly over the new battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marko 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 1,998
