I would like to be able to repaste my cpu.
I have gotten to the point of taking off the key bard but I have not been able to get to the cpu though I see it.
Hey there Henry, If there is screws on the bottom of your laptop, remove them, and keep note to the order they belong in, as well as there may be some hidden screws underneath riser pads or security stickers. I would also recommend unscrewing any screws underneath the keyboard. Once the bottom screws are removed, this should allow for the bottom panel to come off, and allow you to safely use a flat edged tool carefully pry the top of the frame off. Hopefully this will shed some light on getting it open
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 145
