跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2266 个问题 查看全部
help - home button :((((
Guys, please I need an urgent help :(((
I got an iphone7 with broken display and it was changed, but now the home button doesn’t work anymore. I asked to change the home button but still not working.... I’m trying to access the phone but it’s on the “press home to open” and it’s not possible...
Is there another way to access the phone without the home button? What should I do? :(((((
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I'm not sure on accessing your phone but it does sound like when the screen was replaced the home button ribbon cable was damaged.
这个答案有帮助吗?
得分 1
添加一条评论
I hope you still have the original home button! the 7 will not work with any other home button each button is unique to the phone. if you have the original home button try it on another new screen because sometimes the connector on the screen is bad. hopefully you haven't damaged your home button flex.
这个答案有帮助吗?
得分 1
3条评论:
I think that the original home button is damaged... I know that any other button won’t replace the touch ID, but I thought that the home button would still work... Do you sth about this? It should work, even without the touch ID, right? I really need this phone to work
完成的
I added pictures
完成的
no all the iphones it will work as just a home button from 7's and up it will not work at all. I see yours is damaged there is a chance you can get it to work by getting the chip switched to a new button.
完成的
添加一条评论
添加你的答案
Maiara Fontana 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 144
