跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
iPhone 4 clock losing time
I was asked today about an iPhone 4 (A1332) which seems to have a problem with the real time clock. Now and then it loses maybe half an hour and then recovers the correct time a day or two later. Text messages don't seem to come through when it's in that state.
I suspect it could be a problem with the RTC chip (probably not a separate chip but a function integrated into the processor or one of the peripherals) in which case it's probably not fixable.
Probably the only chance of a fix would be if it's a software problem, so I suggested backing up her data and doing a factory reset. But if the flash memory is getting tired a complete reflash of the kernel would be more likely to do the trick. Not sure how to do that. Ideas? Or other suggestions?
Regards - Philip
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@pleriche this "Text messages don't seem to come through when it's in that state" sounds more like a connection issue. Check the antenna cables etc. If not check with a new Sim Card and see if that will help.
完成的
添加一条评论
1个答案
已选择的解决方案
Real time clock is a waste of time to diagnose on a old phone. Better yet to get another 2nd hand iPhone 4 rather than try to fix the problem as it would be a lot cheaper and less time spent.
You could try restoring the phone via iTunes but you would need to do a backup first. I doubt it'll help though.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Philip Le Riche 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 169
