跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
MacBook overheats and fan goes off while I play games.
Since I play games such as the Sims 4 on my Mac, it will sometimes overheat (I usually play it with my computer on the table but sometimes in my lap) and around the top left area of my keyboard will get pretty hot.
The fans usually go off and it's fine, but is this an issue? Should I play the game less for my laptop's sake?
What should I do? Please help!! My computer is only 2/3 months old!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Its hot around the top left as that is the fan exhaust. for reference, keep it between 50-95F (10-35C) apple says.
这个答案有帮助吗?
得分 1
添加一条评论
I think 3D games is not fit macbook air, try 2D games or buy a laptop with a independent video card.
这个答案有帮助吗?
得分 0
添加一条评论
Macbook's aren't great gaming computers unfortunately, I wouldn't suggest using it to play games on as it may blow a circuit.
这个答案有帮助吗?
得分 0
2条评论:
Yep, that's why I stopped. My fans would go off when it wasn't hot and it'd have problems shutting down, so after I stopped playing games for a while none of that happens anymore.
完成的
I've gotten away with Sims 3 on my 2011 13" Pro. It's the Air that has issues - the Pro has no problem with moderately heavy games. Sims 4 also works, but I need to run Legacy Edition due to Metal 2.
3 ramps the fan up more then 4 too, which is surprising. That said, it runs loud since I set it to high.
完成的
添加一条评论
添加你的答案
Morgan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 2,215
