跳转到主内容
加入维修社区 - 创建账户
Can’t reinstall MacOs because disk is locked (2nd hand MacBook)
So I got a second hand macbook pro. I tried to reinstall macos, but it says that its locked
People said that i should go to disk utility and unlock the locked disk there
But the locked disk wasn’t there
And even if its there, i don’t know the password too. And I can contact the owner anymore
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 17
5条评论
I have the same problem, did you find a solution?
完成的
Replace the drive. Drive firmware passwords on macs as far as I know are not something you can bypass.
完成的
I'm curious what would happen if you clicked the ”View” menu there in the upper left corner of the Disk Utility windows (second screenshot)?
Then you should be able to ”Show All Devices" which will probably show you the ”volume structure” of the internal drive.
Try to select the top item in this structure and then click the ”Erase” button and format it using the APFS file system if installing High Sierra or later.
完成的
I encountered the same problem, Mу OS installation was giving me errors.
I had to research several guides on the internet in order to try solve the issue.
Follow thіѕ guide hеrе: https://bit.ly/3i7wK8D
It should be helpful
完成的
添加一条评论
8个答案
已选择的解决方案
You'll need to visit an Apple Store with a copy of the sales receipt for them to unlock your system.
Update (02/24/2018)
How to set a firmware password on your Mac
这个答案有帮助吗?
得分 4
4条评论:
I don’t have any receipts
完成的
Thank you dan but that is not helpful, mac air boots to the login screen but password not accepted, when I boot to recovery mode and click on info tells me the drive is locked. I can unlock the drive and see all correct info about drive and files etc but when I reboot laptop back to square 1
完成的
Then your system is iCloud locked! Which is why you need to go to an Apple Store to have them help you.
A company in China had figured out how to locate systems hidden ID code from an Apple web site used to validate if the phone was iCloud locked so they could reprogram locked phones and systems. Apple quickly shutdown it down once discovered. Basically, they plugged in a S/N and if it was clean they would use it.
So now years later the cloned system was stolen or Apple discovered the duplicate they would lockout the newer system with iCloud. You are one of the lucky ones who's system S/N and its hidden ID was cloned.
完成的
Ours also says disk is locked! Such a bummer because now I’ll lose thousands of photos and videos of our little ones as a babies. Is there a way to get this back? If Apple unlocks it, will all those be gone? I assume they would just wipe it clean? Anyone know what the cost of this would be? Wondering if we should just toss this if all hope is lost. Thanks for the help.
完成的
添加一条评论
最有帮助的答案
@tindc from this old thread it sounds like you just need to
Go to Disk Utility --> Erase Disk --> Select Erase with Journaling.
locked hard drive can't reinstall Lion OSX
@danj also suggested in this solution to create a separate bootable thumb drive to reinstall OS X from, erase the disk using Disk Utility, and that apparently solve the issue.
这个答案有帮助吗?
得分 9
13条评论:
@avanteguarde as you can see from the image above under my disk Utility, the earase button is gray and i cant click it
完成的
@tindc my bad. I mistyped. I mean the "Partition" button. Try using the "Partition" button and select 1 partition. Also, are you using a thumb drive or directly from the Mac? You need to boot from a thumb drive.
完成的
@avanteguarde under dosk utility i only have “disk images: OS X Based System” i tried what you said i click partion, somethinf popped out, the format is gray i cant change it to journaled
完成的
I also can’t add 1
完成的
@tindc you need to boot from a thumb drive. You need a second mac to create a OS X installer. Find another computer with High Sierra. Follow these instructions:
https://www.macworld.com/article/3204672...
Then put the thumb drive into your computer, and hold "Option" when starting up. Choose Start up from the Thumb drive. This version of Disk utility will let you erase the drive.
完成的
显示更多的8条评论
添加一条评论
Try this:
Restart , Hold down CTRL+OPTN+R
it should get into internet recovery, Circling globe and it will end up in disk utility page.
Click on disk utility and erase the hdd from internal only once done go back and go to reinstall Osx sierra.
这个答案有帮助吗?
得分 3
2条评论:
it is actually CMD(command)+OPTN+R
完成的
used CMD(command)+OPTN+R
Then I was able to install macOS Big Sur
完成的
添加一条评论
I also had an issue with a locked disc when I was in recovery mode.
I ended up installing High Serria on a thumb drive, rebooting the mac holding down command, and selected the thumb drive to boot from. From there I was able to erase the mac's hard drive with JOURNALED selected. Exit disc utility and installed High Serria. It's installing now. I'll message again if there are any problems.
这个答案有帮助吗?
得分 2
3条评论:
Ryan, did it work?
完成的
Won’t erasing the HD delete everything on it?
完成的
It works for me. hold the command+option+R then wait for the globe until it finished loading, then the erase button is now enabled then you can erase the mac with journaled after its done, back to the installation and it will now continue, it actually works and waiting for 6 hours to finish the installation.
完成的
添加一条评论
I have a similar problem, the drive is locked, I can unlock it and run first aid but when I reboot drive is locked again.
这个答案有帮助吗?
得分 1
2条评论:
Has anybody solved this without erasing the HDD? Surely there is a method. I was midway through updating the OS to El Capitan (yes I’m out of date) when my Mac crashed. I force turned off and now when I boot back into recovery modes I can’t reinstall/update the OS as the HDD is locked.
完成的
添加一条评论
1.) Open the terminal from the reset mode.
2.) Type this command in: diskutil list and hit enter.
3.) If there are no errors, type this command: diskutil unmount force /dev/disk0s2 and hit enter
4.) You will now be able to look at all of the actions through Disk Repair (erase/partition)
5.) Select Partition and create a new partition (select OSX Journaled)
6.) Hit continue and if it works then you can go to download your operating system and your disk will see two disks. Select the disk that is no longer locked.
这个答案有帮助吗?
得分 1
添加一条评论
IMac disk locked, macOS cannot be reinstalled, disk erase not functioning and the only solution is for you to say take the device to an Apple Store to unlock, Oh my God, that means apple does not a solution to what it has built, If a person will encounter such a problem then it has to be taken to Apple Store? to unlock it. This is crazy. So Apple should come out to tell us that us in Africa and places with no Apple Store are not supposed to use apple devices. This is nonsense
这个答案有帮助吗?
得分 0
2条评论:
@adamby2k3 - Think of it this way you stole the persons laptop and you want to see what is on the drive should you look?? Nope!
Thats why this is the proper answer! If the system was truly yours then Apple might be able to gain access beyond that you'll need to erase the drive, that way the data is gone!
完成的
u dan r stupid beach my friend adam is good guy stop saying he stealing
完成的
添加一条评论
Go to recovery > utilities > terminal
Type in “diskutil list” and find the disk i.e. disk7s1
Then type “diskutil apfs unlockVolume /dev/disk7s1”
Put in your password and it should say unlock and mounted APFS volume. Not you can reinstall OSX or repair disk.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Martina 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 35
过去 30 天: 136
总计 238,704
