跳转到主内容
Repair guides and support for top and front loading Whirlpool brand washers.
425 个问题 查看全部
Why is the solenoid overheating and smoking?
My Whirlpool top loader washing machine wouldn't go to the spin cycle. I changed the timer with no luck. I changed the solenoid, which went bad a year ago and was changed, and I got one load out of it. The second load, mid cycle, made the solenoid get hot and started smoking. I reinstalled the older solenoid and the machine started and this solenoid started getting very hot. What is going on?
Model: Whirlpool Stylemaster No. 4213631
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论:
@atomicv8 what exact model is your washer and which solenoid did you change?
完成的
I may have mis named the unit. It's the capacitor in the left side of the washer control panel. It's a whirlpool heavy duty large capacity 6 cycle unit.
完成的
I can't find a model number, but the inside of the lid says Stylemaster No. 4213631. I pulled the motor and it spins freely, there are no damaged wires to be seen. Why does the capacitor smoke so much?
完成的
@atomicv8 Post some good images of what you are exactly looking at etc. with your question. Use this guide 在已经存在的问题里加入图片 for that so that we can see what you see.
完成的
The model number of the machine is LA8860XWQ0. Is it possible the capacitor wires were crossed, causing the heat and white smoke?
完成的
添加一条评论
1个答案
not sure and not sure why i gotta answer all these questions lol
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tom Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 312
