跳转到主内容
加入维修社区 - 创建账户
发布于 2015 年,这款一体式摄像机具备 WiFi、蓝牙和防水功能。与 HERO+ LCD 相比,它缺少触摸屏显示器。
gopro won't do anything
hero HD LCD just quit working won't turn on, charge nothing just quit one year old what to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Please press and hold the Power/Mode button on the front of the camera for about 10 seconds, then release it.  This acts as a rest and in most cases, this makes your camera power ON again if the battery has a charge.
  1. If the camera doesn't power ON, let's try charging the battery.  Please use the supplied GoPro USB cable to connect your camera to a USB port directly on your computer or to a USB wall charger that outputs 5V and 1A.  Once it's connected, you should see a red LED light up on the front of your camera within no more than a couple of minutes.  If you do not see a red LED illuminate on the front of your camera, please try pressing and holding the Power/Mode button for 10 seconds while it is still connected to the USB cable.  If the camera still doesn't power ON, please try these same steps using a different USB cable and USB port or charger.
  2. When the camera is connected to the USB cable and USB port or charger, you should see the red LED light up on the front of the camera.  This indicates that your camera is charging the battery.  With the front red LED lit up, your camera should reach a full charge in 2 hours if connected to a wall charger that outputs 5V and 1A.  If connected to your computer's USB port, it may take up to 4 hours to reach a full charge.  Once the red LED shuts off, your camera's battery has reached a full charge
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
robert m dykes 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 22
总计 663
