跳转到主内容
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 个问题 查看全部
Read Hard Drive 128GB Samsung 1.8" Sata LIF
My 1st Generation Macbook air has died. Overheated fault on the main board. Power Loop issues. I have retrieved the hard drive out of it.
How do I read it.
Get an 1.8" enclosure?
What do you suggest any links?
What's the difference between ZIF & LIF?
What the easiest cheapest just want to wipe the drive & put it back into
sell the parts on.
Update (02/21/2018)
Is this drive enclosure the thing to buy?
Amazon - DELOCK Gehaeuse 1.8 micro SATA USB 3.0
Delock Product Page - Further Specification.
Can anyone confirm? It looks like it can do the job.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Hi Jason, did you find the enclosure for the 1.8” SATA LIF? I have the same hard drive removed from Mac Air. Thanks
完成的
Mine had a Samsung drive in it. 24 pin LIF. Most are 40 pin. You have to be super careful to get the correct one. https://www.ebay.co.uk/itm/KALEA-INFORMA...
完成的
thank you. I will have a look at this :)
完成的
Did you manage to do this?
完成的
添加一条评论
1个答案
已选择的解决方案
ZIF and LIF use the same cable.
The difference is the way the connector locks onto the cable.
This old thread should give you a better idea what you want.
HDD to SSD
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jason G 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,060
