跳转到主内容
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
How do I find the model number
Hi I have a Kenmore elite washing machine. It was free and used when I received it and the serial number sticker is gone I linked a picture of the appliance. Please help it seems like the drive gears are grinding. Like the couplers are broken. I just need the model number so I can order parts. Or if you could link a part number that would be awesome.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Check the back of the washer's control panel, the upper left-hand corner of the back of the washer or the lower left-hand corner on the front of the washer. The model number might also be on a sticker under the lid or on the inside right back corner -- open the lid to check this location.
这个答案有帮助吗?
得分 2
5条评论:
I checked all of these spots. There is no label anywhere
完成的
that makes it tough. Let's see if we can get it from a part number. See if you can find a part number on the main control board.
完成的
This is my part number 8564990
完成的
@muggasticks65. no luck, got anything else?
完成的
What is the load capacity of Kenmore washer HE Top Loading Mod 110.20372711. Ser C809701665
完成的
添加一条评论
My part number is 8564990
这个答案有帮助吗?
得分 0
添加一条评论
Hi don't know if you got your answer but the umber is 1105962401. I have the same one and can't figure out how to remove the shell so I can see where it is leaking. Any clue?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chuck boyer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 78
总计 4,655
