跳转到主内容
A1708/EMC 2978—于2016年10月上市,这台入门级MacBook Pro保留了它传统的功能键(相对于OLED触摸条)。功能键版本带有英特尔酷睿i5和2个雷电3端口。
Replacing LCD only in this model
Hi.
Anyone have experience replacing LCD only in this model?
I have done several A1502 MacBooks, but this looks kinda different.
How is the overall LCD repair, compared to A1502 13" Macbook pro?
Is it much the same, or did Apple make replacing LCD much worse ? :)
Thanks a lot!
Best
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Were the ones you did Retinas or pre-Retina?
完成的
A1502 is retina models :) So yes to retina
完成的
添加一条评论
1个答案
I did my first repair on one about a week ago. It was quite easy less work for sure. Don't have a guide so you'll need to wing-it.
Follow the IFIXIT 带功能键版本的 MacBook Pro 13寸 2016年末款拆解 to Step6 then jump down to Step19 to take the antenna unit off and gain access to the display ribbon cables. Once you've disconnected them pop the hinges.
这个答案有帮助吗?
得分 0
5条评论:
Hi Dan.
Thanks a lot !
Would you rate this repair "the same" ( or pretty much) as the A1502 13" retina?
Best Anders
完成的
As I stated it was easier! But I only swapped out the full display assembly.
I don't try replacing the LCD sub assembly in any of the retina models its just too difficult! I only do the LCD's on the older unibody non-retina series.
完成的
Okay. Was referring to a "LCD only" repair for this model. The LCD only repair is a lot more time consuming, and harder. Thanks for reply :)
完成的
@ajes - Are you even able to get the panel?
It took some doing to even get the display assembly to fix this one.
Between all of the sheets and the dust issues! You'er a better man than me!
完成的
The most difficult thing is the dust, yes. And cleaning up the edges for glass shards. Even the tiniest shard could break the new LCD. I must admit it took me a lot more hours to do this repair. (If I made it sound easy, it wasn't).
完成的
添加一条评论
添加你的答案
Anders Laursen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 282
