Mac Mini 2011 with Radeon beeps 3 times and flashes light 3 times
Not switching on How to fix it? :(
Well your error condition implies your RAM is bad or the wrong type for your system. Did you upgrade your RAM? About Mac Power On Self Test (POST) RAM error codes.
References:
这个答案有帮助吗?
I've tested with 3 other RAM modules 1066MHz and 1600MHz (I know it is only 1333MHz - but I know they are working with those speeds as well)
And my modules are 100% working
I've tried to put one module at time - to each slot - no difference
When no modules at all - just one beep :(
Sorry guy ;-{
The RAM slots must be damaged then. You'll need to have the logic board repaired or replaced.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 778
2条评论
What happened? Can you give us some background.
由 Dan 完成的
it was working - switched off - next day this :(
由 Bart 完成的
