跳转到主内容
Startup Disk HDD not recognized... fix/alternatives?
Hi all -
I have a macbook pro 2GHz Core Duo that I recently purchased... knowing it was having trouble booting from the internal hdd. After removing the logic board, cleaning it, reseating, etc... I got it to boot up to the hard disk twice and then it went back to only booting from the optical bay or an external hdd.
I'm assuming this is a hard drive controller issue, correct? Any suggestions? I know I can remove the optical bay and install the after market hard drive bay, but if I want to keep my dvd drive, are there any fixes? I did note that all the pre-unibody macbook pro logic boards have an unused port site to the left of the optical bay but before the memory opening. Is that a potential site I could link some "X" cable to?
Thanks
PS - I tested using both another HDD and another HDD flex cable
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes you can use the optical bay adapter: [关联产品丢失或禁用: IF107-078]
You might want to consider replacing the hard drive cable: MacBook Pro 15" (Model A1150) Hard Drive Cable
Do not use that port, it is for Apple factory testing.
Connects hard drive, sleep light, IR sensor, and Bluetooth board to logic board.图片
产品
$14.99
这个答案有帮助吗?
得分 1
1条评论:
Hey Mayer --
It's been awhile, hope all is well. I actually tried a KG hard drive flex cable. It's definitely something related to the hardware of the board or pins on the board. Oh well... Thanks
Jason
完成的
添加一条评论
添加你的答案
jcarter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 2,465
