跳转到主内容
Released in 2013, this laptop comes equipped with a 16” LED-backlit screen, 500GB hard drive with 4GB of RAM, and pre-installed with Windows 8. It also comes with a built in HD webcam and digital microphone, as well as Dolby dual speakers.
CPU Upgrade from A6 to A10
I have a new A10 with compatible pin config.
But A6 is glued to board -- will glue gun damage board? Other options to remove glue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
It is clearly glue -- it is only on the four corners, it is clearish, and I have been slowly slicing away at it with a razor. No signs of solder yet...
完成的
Ok, well if its glued on, its a highly resilient epoxy considering CPU temperatures sometimes reach 85 C (185 F).
完成的
添加一条评论
1个答案
最有帮助的答案
I don't think the CPU is glued to the board.
Rather, I think the CPU is Soldered to the board.
If you are comfortable with soldering, you need to remove the solder from hundreds of pins and make sure the new one aligns perfectly, and that none of the pins are blocked, damaged, or blocked.
Also, the HPs BIOS needs to have information in about the A10 in order for the CPU to work, even if the pins align.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
J.J. Lukas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 262
