跳转到主内容
The Samsung Galaxy Tablet E 9.6 was announced June, 2015 and released on July 2015.
weak wifi signal and dropping
im having problems with wifi on a tab e that i have replaced the digitiser connector on, its a very weak signal around 1 bar but sometimes none and drops out. the router is about 2 metres away. another samsung tab connects fine my a3 connects fine, just a problem with this 1. it has been reset but still nothing. any ideas
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
can your bluetooth connect to any of the devices?
the tablet uses different antennas for pickups, but the same chipset for processing the signals. so if your bluetooth is failing as well, you will be looking at a board level issue, and if your Bluetooth works, then you have an antenna failure.
这个答案有帮助吗?
得分 0
3条评论:
yea bluetooth is working
完成的
think i found the problem a pin has been broken off
完成的
welp, then i guess repairing that is your first step!
完成的
添加一条评论
Hi. Same exact thing happened to me. After replancing digitizer, Wifi got wonky. Bluetooth working fine. But I don't know where the wifi cable/flex/pins (or whatever) are so I can check . Can you show/tell me? Thank you.
这个答案有帮助吗?
得分 0
添加一条评论
There is a chance that the WiFi antenna was damaged during the replacement. The antenna is located in the top right corner of the housing, right by where a pry tool will go for removal. Try having whoever replaced your screen replace that as well, because that repair person is at fault here.
这个答案有帮助吗?
得分 0
1条评论:
Sounds like she replaced it
完成的
添加一条评论
添加你的答案
daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 25
总计 2,391
