跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Can I replace my SE case?
I sat on my phone in my back pocket and the aluminum case is slightly bent around where the volume buttons are. Can I take it apart and reinstall everything in a new case? The screen is ok, the battery still lasts long and everything works fine, the phone is just crooked.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
You can probably find a 2nd hand body on ebay with some patience. Try to go for an original one that's being sold for spares, thus you'll have to shift only your logic board from one to the other. It should be relatively inexpensive, round 50€/$ or less depending the country you are.
You could find a replacement housing too, but shifting all small parts is delicate and potentially dangerous for the overall integrity.
Since you appreciate your phone that much sounds like the most reasonable and inexpensive solution to me. Just follow the ifixit guide to replace correctly and risk free the board and it will be a couple of hours work at the most to get your phone back in good shape.
这个答案有帮助吗?
得分 2
添加一条评论
Yes it is possible, but its very time consuming.
这个答案有帮助吗?
得分 0
3条评论:
Where can I buy the replacement case?
完成的
Just go to apple mate
完成的
It happened a couple months ago, less than 2 months after I purchased the phone. I called Apple 3 times and tried to have them help me but no coverage for this kind of incidents. I can understand, it !#^&@! me off but I broke it so I guess thats on me. My phone was in an Otterbox too, so I did not even notice the damage until I took it out to clean it...
完成的
添加一条评论
It is definitely possible but will take multiple hours and may not work. I would recommend taking it to an authorized repair provider or to apple directly. If it is still under warranty apple will repair it for free.
Do not try to bend the case yourself. It will just cause more damage.
Also if it is under warranty do not try anything at all. Just go to apple.
这个答案有帮助吗?
得分 0
3条评论:
Even if under warranty, Apple will not repair for free damages from incidents. You can read that for yourself on Apple site if you take the trouble to read terms and conditions.
完成的
Indeed they will not repair it. I have bought my cel provider's phone incident insurance so I will probably claim it as lost and get a new one at some point, I just tought it would be nice to fix it since I love it it's my favorite iPhone ever and they dont have them anymore so I will have to get something else... Bummer
完成的
@arbaman Apple will repair it depending on the situation that it was done under. That , I do not know.
完成的
添加一条评论
添加你的答案
Simon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 27
总计 1,196
