跳转到主内容
型号A1288,闪存容量:8、16及32GB
450 个问题 查看全部
why are my apps flashing then going back to the home screen when i tap
tap apps then flash to game then goes back to the home screen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 26
15条评论
I dont know y my messenger cant open in apps than when I have open the apps it close back ownself and go back to home screen again..is oni happens in this 1 app others is jus still and okay nothing happend.
完成的
I have a iPod touch 6th generation and I only got it last year and on my Amazon Music app when I tap it , it just goes back to the home screen and I tried to double tap it and click on the app but it does the same thing.
完成的
My iPod 5th generation want let me get on off-road outlaw I can buy a truck but when I go to play on the map it just goes back to the home screen ever since I got the game
完成的
How can I STOP my screen from flashing colored lights WHEN I RECEIVE INCOMMING CALLS?
完成的
On my Android I go on Snapchat and when i go to message someone it goes there but then it goes straight to my home screen. It will let me do other thing like add to my story but it won't let me text my friends
完成的
显示更多的10条评论
添加一条评论
12个答案
已选择的解决方案
basically that's a sign that the app has crashed - the app quits and you go back to the home screen.
have you tried powering your iPod off and then on again? sometimes a power-on reset can clear up crashing apps that have just been downloaded and installed. try that first and report back if any change. also, is this all apps, or only certain ones?
这个答案有帮助吗?
得分 28
23条评论:
Try as "Back" said hard reset it....
完成的
does it work for iPhone 4s???
完成的
It still doesn’t work after I tried all thise things
完成的
My Instagram not letting me get on my page it keep going to my homepage then when I log in on someone else page it work
完成的
For me it’s just a single app
完成的
显示更多的18条评论
添加一条评论
I got the solution just go in settings then apps then open the three dot menu and click reset app preference
it worked for me
这个答案有帮助吗?
得分 5
4条评论:
What about on a iPad . Facebook ok my phone is working
完成的
Mine still doesn’t work, I tried powering off my phone TWICE and that still didn’t work. The app that doesn’t work is Snapchat. Can someone help me?
完成的
Omg, mine is doing the same thing today and I’ve been researching and looking at everything and nothing has worked. Idk if it means that it was hacked but I hope not
完成的
My phone goes back to main screen when I am typing ,does anyone have this problem,? I can get back but it will do it again
完成的
添加一条评论
it happens to me all the time somtimes u have to turn it off and some times u just dont go on it for a view days and wait and try again
这个答案有帮助吗?
得分 2
添加一条评论
I can’t go into my messages
they flash up then phone goes straight back to the home screen
can’t do anything with messages!
ive turned off and on
reset factory settings
nothings worked
这个答案有帮助吗?
得分 2
2条评论:
I have Huawei P30 Pro, when I'm typing on viber or insta direct after few seconds, and also when I'm typing this comment... It returns me on home screen. Please help
完成的
I have the same problem with my p30 pro also and my mam has the p30 lite with the same problem!
完成的
添加一条评论
I restarted my device and that was the only thing that worked. I tried all the other ways and all of them didn’t work for me. To restart hold down your power button and it will give you the option to power off or restart and press restart. Hope this helps!
这个答案有帮助吗?
得分 2
1条评论:
Sometimes when you have too many photos or apps your phone gets caught up and freezes
完成的
添加一条评论
My Snapchat kept crashing so I deleted it and went to re-download it but in the App Store it still says open in stead of download. I’ve restarted my phone and reset my setting but nothing will work. How do I fix it ?
这个答案有帮助吗?
得分 1
1条评论:
Did you figure it out Bc now mine is?
完成的
添加一条评论
Every time I try to play dip master it loads and goes back to the home screen?????? ???????HELP?!?!?!?!?!?!?!?!
这个答案有帮助吗?
得分 1
2条评论:
My iPad is doing the same it loads pool game then goes to home screen
完成的
My iphone does the same thing it loads mcvs and then goes to my hs
完成的
添加一条评论
I tried that it still does it it comes on like it's going to work thin goes black thin home screan
这个答案有帮助吗?
得分 1
添加一条评论
Try to restart you phone or whatever you have. this helped me so i hope it help you too!
这个答案有帮助吗?
得分 1
添加一条评论
why when i’m on snapchat my phone goes back to home screen after a couple minutes?
这个答案有帮助吗?
得分 0
添加一条评论
It's. Probably bc ya got a Samsung
这个答案有帮助吗?
得分 0
3条评论:
Also when im typing the typewriter just goes away n i have to keep trying n trying !!! Its doing it now as we speak !
完成的
Nah. Just cuz that happens don’t mean someone got a Samsung. I have an IPhone 8 and my Snap does the same thing, and I don’t know why people still care what kind of phone other people have like wtf. If you had a Samsung you’d be sayin the same thing so don’t say “it’s prolly cuz you got a Samsung”
完成的
bro I have an iPhone 8 plus
完成的
添加一条评论
Today my app won’t open I’m guessing it’s crashing and sending me to the home screen because of the notifications. Don’t delete the app I’m guessing if you turn off the notifications for that certain app, it has a possibility that this can be the fix.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
madi reynolds 将永远感激不已
浏览统计数据:
过去 24 小时: 22
过去 7 天: 139
过去 30 天: 656
总计 153,747
