跳转到主内容
Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
116 个问题 查看全部
How to factory reset the Fire stick without any remote or app?
Why is my Fire Stick disconnected from the internet after I ran a "Share it app"? The remote also stopped working. I can't use the Fire TV Remote App as the Stick has no internet access.
I sideloaded an android app "share it" it on firestick but when I tried to send the data from my phone to fire stick, the screen just froze. I had to restart the TV but by then fire stick had lost the network access. Fire Tv -Stick is dispaying "No network access" message. Earlier it was connected to two modems but now its not detecting either of them. Somehow remote also stopped working. I tried two diffrent physical remotes (with fresh batteries) but now I can't navigate inside it by any means.
I don't know the reason but I guess the ‘share it’ app tried to create a shared hotspot network to allow data transfer but maybe fire stick is not configured for it.
Is there any method to factory reset the device without turning it on ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 14
13条评论
I have this same exact issue. Brand new firestick from the store. Loaded es file explorer and moved 2 apk’s that I’ve placed on 4 other firesticks and using the same method.
After the transfer I didn’t jump back to the firestick immediately, but when I did I noticed it was a black screen with “no network connection” in the lower left corner.
The remote wouldn’t work nor WiFi. After a few power cycles and being quick with keeping the remote buttons pushed I managed to get to factory reset.
That worked until I got signed in to my amazon account and then it lost network connection again and it’s stuck at a point (sign up for prime) spot that the remote will not work after power cycles and is at this point bricked. And all before I could actually install anything :/
完成的
@christopher715 Thank you!
@jonschr yes i was looking for something like that only, but a USB mouse worked for me. Thank you!
@stephen Thank you so much, I did get to try your method but it looks very promising. :)
完成的
What is a usb mouse
完成的
I had a Firestick 1
Dead no remote.
With a pin lock.
Linked to computer with ADB with usb lead( jocola.com)
With windows but you can download apple or Linux version.
Plugged in hdmi end into the display
It asks to set Firestick to usb debugging.
No mouse or control.
Downloaded CetusPlay app on both an android or iPhone.
Linked android or iphone as hotspot
You are then able to access Firestick system settings
Go network and link network hotspot
Link Wi-fi
With Cetus
You do not have the facility with Cetus.
For the next move
So download Firetv App.
Link firetv app
Go to setting again.
My device/ my fire tv
Reset factory defaults
Then press the reverse and fast forward button at the same time.
Until factory reset comes up.
I think it took 10/ 12 attempts to achieve a factory reset.
Press reset.
You should then have a virgin Firestick as new
Took a bit of working out by trial and error.
This also circumvents pin code lock.
Nothing else worked for myself.
I now have a clean Firestick.
Good Luck
完成的
Seems long winded.
Just follow each step.
It actually works without have to buy-extra leads or a mouse.
Once you have ADB installed on you computer your half way there.
Using version 3.8.
All free software.
完成的
显示更多的8条评论
添加一条评论
18个答案
已选择的解决方案
I don't have a fire stick remote and the fire stick is signed into another Wi-Fi and on the app it says you have to have them both signed into the same Wi-Fi network how do I fix it to where I can just put the fire stick in my Wi-Fi so I can use my phone as a remote? Please help LOL.
这个答案有帮助吗?
得分 4
8条评论:
You have two options
1) either borrow remote for someone if you dont h
want to buy
2) Buy either of two acessories (very cheap)
Micro USB Host OTG Cable with Micro USB Power for Nexus 4 5 7 10 Galaxy Nexus & Samsung Galaxy S 3 III 4 IV 5 V. https://www.amazon.in/dp/B00CXAC1ZW/ref=...
OR
Amazon Ethernet Adapter for Amazon Fire TV Stick https://www.amazon.in/dp/B01M19P4GJ/ref=...
完成的
Mine factory reset itself But mine is stuck in one place repeating the same message in different languages asking to push the house button to ten seconds i did that nothing happened and I don't have a remote I did getbmy neighbors remote but it wont do anything I change the batterys
完成的
I used my smart TV remote to change the network! Worked like a charm
https://youtu.be/zRitpaGTkr4
完成的
My FireStick wifi trouble started soon after I attempted to run a send-receive thru ES FileExporer which must have corrupted the wifi configuration settings within the Network Settings module as it unsuccessfully attempted to create a hotspot on the stick! It wouldn't display any wifi ssids but displayed the shocking mssg Wired Ethernet Disconnected!! But fortunately my remote was still being sensed. As suggested above, I grudgingly did a Factory Reset and was greatly relieved to get the stick running normally again! Must be very cautious as creating a hotspot isn't supported on the FireStick TV and that screws up its wifi configuration. Thanks All!
完成的
@afstvuser
Did the same thing with ES FileExplorer but remote also quit working. Connected 3 legged OTG cable to use usb mini keyboard for navigation. Able to get to settings for Factory Reset. Got remote working again (https://www.amazon.com/gp/help/customer/...) Just dumb enough to try this ES FileExplorer thing again, this time only lost wi-fi. Not willing to do Factory Reset I kept playing around. Went to settings, >my account, >amazon account, and did the Deregister route. Wi-fi took care of itself and just had to Reregister the stick.
完成的
显示更多的3条评论
添加一条评论
最有帮助的答案
You can connect using just your laptop. Download mobomarket for android on your PC. http://www.mobomarket.net/ Download adbLink 2.04 for Windows: http://jocala.com/ Connect your firetv cord to the usb port on your laptop instead of power. Mobomarket and adblink should recognize your firestick. Select remote on adbLink. That's how you will navigate your firetv. Use left/right and select to navigate. Select Full Screen in Mobomarket under the tools tab. That's how you will see the homepage of the firestick. You will have to keep refereshing the full screen button to see where you're navigating by closing and opening it. It only shows screenshots of your firetv display. Try to navigate to firetv settings and network connection. Select your phone's hotspot and don't use a password. Once your firetv is online, download the official remote for kodi and add host, find kodi.
这个答案有帮助吗?
得分 6
10条评论:
This worked exactly as described. The navigation is a little slow and cumbersome but it gets the job done. Thanks for the tip!
完成的
Ok, This how I refreshed the network connection (wifi) without a remote:
1. Download the tool from www.jocala.com and installed the utility.
2. Connected my Fire Stick to the usb of my PC.
3. When the interface opened, I went to Edit selected Android (see picture of my settings). Somehow I got it to connect just by playing around with it. Once it connected, I kept the usb plugged into my PC, then I plugged the HDMI part of the Fire TV into my television. I selected the keyboard on the interface, and when Fire TV loaded, I was able to use the keyboard to navigate. I went to setting and changed the network settings.
The following link is to some screenshots of my settings:
https://drive.google.com/drive/folders/1...
Hope this blesses you all!
完成的
Hi Stephen, I have a problem with my fire tv 4k. After I installed an app on it, it started to boot loop, I only see the white screen with orange fire tv, and it keeps rebooting. I had allowed 3rd party apps to be installed, but not the other option, to adb connection. Do you think its possible to unbrick it? Thanks a lot
完成的
My issue is adb keeps telling me "device unauthorized" ... and the only way I see to authorize it is with a remote on the TV
完成的
Yep same here , "device unauthorized" screen is asking me to authorize access with the laptop which I obviously cannot.
完成的
显示更多的5条评论
添加一条评论
Well, I tried something crazy…
  1. I setup hotspot on one of my mobile phones with the same name as my old WiFi (which my Fire stick remembers)
  2. Make sure you match the hotspot password also with old password
  3. Turn on the Hotspot and Firestick and bam! It's online
  4. Now, use a second mobile and connect to the same hotspot
  5. Launch the FireTV app and now you can control your Firestick and configure new Wi-Fi ;-)
这个答案有帮助吗?
得分 6
4条评论:
You are really good. Know the concept. It took some time for me but I too could get it done. I was travelling but did not take the remote and your solution really helped!!! Thanks
完成的
This one worked for me, thank you so much. I used an android phone to create a hotspot using my old WiFi address/password. I then connected an iPhone which has the Fire app on it to the hotspot and I could once more navigate around Amazon Fire on my TV and was able to go into settings and log on to my new WiFi. Saved me buying a new remote and also waiting for it to turn up. Can’t thank you enough
完成的
What if the Fire Stick is being set up for the first time and the remote is not working?
完成的
Amazing trick, it worked, thank you. I was about to give up after trying all other options. App wont pair, new wifi, remote needed pairing!
完成的
添加一条评论
Well I found the answer to my question. I connected a USB mouse to the fire stick and tried to naviagte to the network setting. ( I couldn't see the cursor so it was quite hard to navigate)
You can either use a USB mouse or an ethernet network cable. For fire sticks you may use either of following two:
OR
Good Luck!
这个答案有帮助吗?
得分 2
3条评论:
did your remote work then?
完成的
I did a factory reset on my firetv, it's requesting I pair my firetv remote before I can access the TV and I've lost the remote. What can I do to bypass the remote pairing stage so I can access my TV
完成的
Get the firestick app on your phone.
完成的
添加一条评论
Not to be disparaging to you, but really,
"Is there any method to factory reset the device without turning it on ?
Do you know of ANY electronic device that you can "factory reset" without it being powered on?
That's like me wanting to have "remote computer access" with my home computer "powered down"
It's not possible to do. And if you can't use the Amazon App, I don't know what to suggest.
If it's not responding to the physical remote, IF YOU HAVE AN ANDROID PHONE,
you can download the Amazon Fire TV Stick APP from Amazon onto your phone and
see it THAT will serve as a remote and try to do a factory reset on your Fire TV Stick.....
Without some input device, the Fire TV Stick is pretty useless.
这个答案有帮助吗?
得分 0
5条评论:
You can factory reset lots of devices without them being turned on. If you were to "factory reset" a PC, you'd simply connect the hard drive to another device then format the drive and fresh install windows.
Not to be disparaging, but your answer, in addition to being snide, both misses the point of the question and gives out incorrect information – it *is*, in fact, possible, to reset most things without them being powered on; typically it requires connecting to something else with the device to be reset powered off and resetting the memory in some way through the connected device.
完成的
Then why didn't you answer the ^!&$@*%%$%$@$ question, @%^$$@$? Just saying........
完成的
You can factory reset the fire stick using the fire tv app on your cell phone. When the fire stick starts back up you need the actual remote though, in which case if you don’t have, you run into this scenario.
完成的
@ Albert Einstein
Factory Resetting a PC requires BIOS (UEFI) reset, too. Since the idiots that design the things, decide to allow corruption to be POSSIBLE (not necessarily 'a common occurrence' but who knows).
So, reset to known-good settings.
BIOS flashed with backdoored rogue firmware is also possible. Also, Intel ME is a thing. A very bad thing.
Resetting may not remove it. ReFLASHING is a better option, in theory. Also,
Same for android devices, like Firesticks. They work a little different than PCs, the principle is similar.
Vulnerabilities vary - vs. hardware and software installed.
Formatting the HDD is not enough these days (vs wiping data + HDD also has corruptible firmware, USB storage + SSD too).
Good luck! Our tech overlords have mis-designed much! Just look at the shambles that is USB security - the horrible BadUSB flaw has not been fixed in 20+ years of USB standards revision. Even for Apple. The cashflow investment is obviously there, no excuses! Suggests it is left insecure on PURPOSE.
完成的
I was having trouble with my wifi router and had to get a new one but in the middle of all that my firestick went to no network so I kept putting in the information but it wouldn't accept it and then it just stayed stuck on the fireTv or firestick logo. I have disconnected it and reconnected it back but still does the same thing I contacted this guy and he said it was due to my storage being full and then said I can sell you one for 100.00 plus now my wifi network name changed and so did the password due to the router I had was already outdated can someone please help me I am not to tech savvy either with that being said I would like to Thank anyone who takes the time to read this and also if anyone is able to help me out since I know that everyone has busy lives.
完成的
添加一条评论
I rarely faced streaming issues while using Fire TV Stick. There are various reasons behind these streaming issues. Due these problems, we need to reset our device. Each and every user find about why reset fire TV, how to execute the process of Reset? If you are also one of them facing problem , here you can Reset Fire TV Stick with or without using remote.
这个答案有帮助吗?
得分 0
1条评论:
im trying to supercharga a stick for a friend. she has no remote but thats not an issue. problem is she has no code (4 digit) . no code appears on screen as some say and my gallaxy smart phone will pick up on my other 3 sticks but not this???
完成的
添加一条评论
Hello! Can I make a hard reset through adb access? The stick does not load.
这个答案有帮助吗?
得分 0
1条评论:
Just press right on the directional pad and the return button together for about 10 seconds this will activate factory reset
完成的
添加一条评论
So my problem is the following, I'm stuck at the bootloop, tried remote key combo for factory reset (right & back), nothing.
Would I be able to reset it through adb acess? Or any other way? If so, please let me know.
这个答案有帮助吗?
得分 0
1条评论:
please let me know if you managed to solve this problem, q7mplayer@gmail.com
完成的
添加一条评论
Here is the easy one you can follow
Click on Settings> Go to device> select Reset> setup pin and factory defaults. Now your device got reset and secure.
You will be amazed.
Still If you getting issues than comment here i will try to solve it as much i can. or might be you can have a look my blog where i am trying to solve it the issues about
这个答案有帮助吗?
得分 0
1条评论:
Hi I have a problem with Amazon firestick… Firstly due to some reason I was unable to pair my remote, so I thought a factory reset will help it and so I did it using my android mobile app. Now I am completely stuck as after factory reset when the firestick started its stuck on the start up screen asking me to pair the remote and I am unable to do any thing. Highly appreciate if anyone can help with how to setup a firestick without any remote access
完成的
添加一条评论
Edit Answer
Answer Text
这个答案有帮助吗?
得分 0
添加一条评论
Hi I have a problem with Amazon firestick… Firstly due to some reason I was unable to pair my remote, so I thought a factory reset will help it and so I did it using my android mobile app. Now I am completely stuck as after factory reset when the firestick started its stuck on the start up screen asking me to pair the remote and I am unable to do any thing. Highly appreciate if anyone can help with how to setup a firestick without any remote access.
这个答案有帮助吗?
得分 0
1条评论:
Same exact thing I'm going through right now. Extremely aggravated. And I can't find the IP address so I can't connect to ADB!!!
完成的
添加一条评论
im also facing the same issue no wifi and my remote as seemingly vanished and its stuck on the registration screen and iv read all of the above and either there talking utter horse punani or my stick is well and truly shafted
这个答案有帮助吗?
得分 0
2条评论:
Never got any answers . buy roku its cheaper and easier.
完成的
Never got any answers . buy roku its cheaper and easier.and it has a remote for your phone also
完成的
添加一条评论
I have a Hisense smart the Motorola has a orange light the data my cable don't work but internet works
这个答案有帮助吗?
得分 0
添加一条评论
Same problem as above, tried all sorts of key combinations, factory reset is possible as I found out, but puts me in a never ending loop searching for remote. What I should have done was take a club hammer to it.
这个答案有帮助吗?
得分 0
添加一条评论
Oh my God, why did I buy this stupid thing ??‍♂️I am just going to ???‍♂️?? this %#*@ thing. I just want a Chromecast…??‍♂️
这个答案有帮助吗?
得分 0
添加一条评论
Hoping someone can help. I took an old firestick from my parents home. I think a friend jailbroke it to be on “latin tv” because when i connect the stick to my tv it opens on that page. I don’t have a remote and the apps won’t work bc i guess i havent “set it up” to be on my wifi network. So im wondering what could be the best way to reset the stick so i can connect to internet and get out of that jailbroken mode? TIA!
这个答案有帮助吗?
得分 0
添加一条评论
I have had one Firestick for about two years and bought another last Christmas for my grandsons room so we dont need to transfer the device back and forth for him.
Nothing but constant issues with the remote not working. New batteries in both, have tried all the options Ive read to pair, reset remote, reset firestick, etc.
Sometimes one thing will work, other times nothing works and I just give up. Even the remote app on my phone wont work. Nothing is finding the firestick itself.
I am so tired of having to gi through this crap continually.
The remote will turn the tv and firestick on and off but nothing else.
About to bust them both or pull my hair out from frustration. I dont understand why, and I need a better, quicker fix. I am very sorry I bought them in the first place. Love the programming but hate the hassle.
Any help would be greatly appreciated.
Thank you.
这个答案有帮助吗?
得分 0
1条评论:
I believe they all use WiFi Direct to communicate, not Bluetooth. This may be some sort of issue in congested WiFi environments, or there may be vulnerabilities in the comms (unlikely since Amazon has the resources to fix these and the motivation, too. I would look at your wifi environment.
完成的
添加一条评论
Can anybody give a straight answer regarding Amazon Fire TV Stick gen 2 stuck on the start up screen asking to pair the remote? Can Amazon Ethernet Adapter be successfully used when Fire stick is in the stuck mode if we connect it by wire to the same router a smartphone is connected by wifi? Will Android Fire TV app see the Fire stick connected by wire and bypass the stuck screen?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yogesh Arora 将永远感激不已
浏览统计数据:
过去 24 小时: 105
过去 7 天: 753
过去 30 天: 3,554
总计 381,086
