跳转到主内容
The Signet series was Kodak's top American-made 35mm camera line in the 1950's. It is one of only two Signet models that contains a range finder, and the only one not made mostly of plastic.
Why triangle patch is not visible when view through viewfinder
where could I buy a new one beam splitter ,because the coating of beam splitter does not exist and when view through viewfinder the triangle from the rangefinder is not longer visible , and i try using a piece of blank 35mm color negative that has been processed which I put behind the beam splitter, and followed these procedures the triangle of beam splitter is visible , but appears as double triangle, probable first triangle is a reflection of 35mm colour negative film procesed , and the second triangle is reflection of beamsplitter glass.What do you think.Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Your beamsplitter got mis-aligned. Review this IFIXIT guide: Kodak Signet 35 Beamsplitter Replacement. There should be a couple of small setscrews which has some glue on in to prevent it from shifting. One is to adjust the parallax (up & down) the other the infinity set.
这个答案有帮助吗?
得分 3
3条评论:
完成的
This is such an old camera parts will be difficult to find. Maybe you can find a second non-working camera to steal the part from to fix yours.
完成的
Thank you very much
完成的
添加一条评论
添加你的答案
Florentin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 198
