跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
I see a charging symbol, but the battery is not increasing more than 1
My iPhone 7 was working properly for 1/2 year but know, suddenly when I plug my phone to charge the percentage is stuck at 1% or in the best case 2% .
If I disconnect the phone from the charger it stay up for 40s and then shut down. There are times when the phone starts with 100% battery but when i remove the charger, the same problem, it s shuting down and show again 1%
The only thing I replaced was the front glass.I tried multiple cables and chargers without any results.I don`t know if it s the battery or the software, any help please? Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
My phone is showing that it’s charging, unfortunately it’s stuck on 1% and isn’t moving up. What do I do?????
完成的
I hаd the same problem with my iPhone. These problems require a little bit of research on the internet.
Take at a look at this link: https://bit.ly/3hhNOJI
I followed this link and it was helpful.
完成的
添加一条评论
4个答案
已选择的解决方案
You may have partially dislodged or completely removed some tiny components right next to the battery connector on the logic board. One of them is responsible for allowing the battery to communicate the charge state to the CPU. So take out a magnifying glass or loupe and inspect that area.
If that is indeed the issue, it will require a micro-soldering repair.
这个答案有帮助吗?
得分 1
2条评论:
It s not from the glass changing because that was 2 month back
完成的
It could have been partially dislodged months ago and finally broke off recently following a minor drop or impact.
If you are going to ask for help on a forum, don't discard answers out of hand without at least bothering to look first. The worst that can happen is that my hypothesis is incorrect.
Otherwise, use a battery checking program like coconutBattery to test the condition of the battery.
完成的
添加一条评论
最有帮助的答案
You replaced the front glass, did you disconnect the battery before the repair? Any damage to the battery socket, are your cables seated properly within the frame, a pinched or shorted cable has been know to happen when closing the phone.
这个答案有帮助吗?
得分 2
添加一条评论
Try a new charger or get the charging panel replaced.
这个答案有帮助吗?
得分 0
添加一条评论
I don't have a clue what's goings on but my phone is doing the exact same thing and it's so annoying?!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mija Andrei 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 21
总计 28,080
